Rear Seat Belt Removal Instructions
OK, here is how you remove the rear seat belt. It is a little bit of a pain and not worth the effort if this is all your doing. Since I am installing the roll bar, I already had to do most of the work so no problem.
You need to remove the B pillar and then remove the lower rear panel. Then you can see from the photo where the belt is. There are three bolts, 10 mm I think, that you need a 8" extentsion to reach easily. You can just pull back the insulation and it's quite easy.
Don't have exact weights yet but it isn't a lot, 2 lbs maybe. PM me for more details.
Jul 29, 2019 11:13 AM
r_matt_6
Oct 8, 2015 06:07 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
su_maverick
Aug 21, 2015 07:14 PM
