Boost question....
Old Apr 22, 2008 | 07:04 PM
DropGems's Avatar
DropGems is infamous around these parts
Boost question....
My car is modded and normally I get 1.0-1.1 bar on average but randomly for the past few months i'll only hit like .7 bar. Is this most likely the wastegates sticking or is it something else? It wouldn't be the diverter valves leaking cause that would be low boost all the time right? If it is the wastegates, can the dealer fix this problem? Thx for any help.
Old Apr 22, 2008 | 07:05 PM
disconnect the battery for a few minutes... reset the ECU....
otherwise you have a leak...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 22, 2008 | 07:12 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Are your wastegates stock? I had one of my wastegate rods snap and experienced a similar issue.
Old Apr 25, 2008 | 10:03 AM
DropGems's Avatar
Yes my wastegates are stock. Like I said, it's maybe 2 out of 10 times when I get on it I only hit .7 bar instead of 1.1. If there was a leak, wouldn't it occur all the time? Can the dealer find the leak? Thx
Old Apr 25, 2008 | 10:15 AM
vividracing's Avatar
Stock diverter valves? If so SWITCH THEM. Also have the MAF voltage checked. But if the MAF was bad you would be in limp mode and make no boost. I say your diverter valves are leaking for your wastegate is stuck.
Old Apr 27, 2008 | 07:47 PM
DropGems's Avatar
No my dv's aren't stock (I have Baileys Dv's), just my wastegates are stock. If my dv's were leaking wouldn't the boost loss be consistent?
Old Apr 27, 2008 | 10:41 PM
what if sometimes they stick????? many of these diverter valves out there are junk and leak bad or stick cause of design. I could be wrong and it could be your wastegate too.
Old Apr 30, 2008 | 09:19 AM
DropGems's Avatar
Thanks for the responses. Yea, I dunno, I've had the dv's for a couple years and this never happened before, but I guess they could be the culprit. Does the dealership find boost leaks for you or do you have to take it to another shop?
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
