Clutch pedal pressure issues
Old Apr 27, 2008 | 05:33 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
The pressure on my clutch pedal is now changing continuously. When the car has sat a few days, the pedal is stiff until the car fires and I pump it a few times, then it softens. Once I start driving the pressure is never consistent. The clutch will be stiff, soft, or a combo as the pedal is moved.
The clutch itself appears to be working fine, no slippage, and grabbing mid-way on the pedal movement.
Anyone have a problem like this before? Is there a fluid leak and if so where could I check?
Any and all help is appreciated.
Old Apr 27, 2008 | 05:53 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Clutch pressure accumulator. $120 part, 3 hours labor.
Do you also get some overflow from the PS reservoir in the front? Another symptom of the same problem.
Good luck!
Old Apr 27, 2008 | 07:16 PM
MikeR's Avatar
MikeR is infamous around these parts
I had the same problem, as noted in previous post, pressure accumulator. Independent did mine for ~$350 (parts/labor)
Old Apr 28, 2008 | 10:12 AM
WyattTT's Avatar
Thanks for the info.
Mike where did you get yours done?
Old Apr 28, 2008 | 10:24 AM
MikeR's Avatar
A shop here in Temecula, AutoHaus Frankfurt. Tech is Shane. I also have a friend, that can do this on the side. He is the one that installed my turbos. Not sure on his price though, but I can ask if you want.
Old Apr 28, 2008 | 01:40 PM
WyattTT's Avatar
Ive heard of that shop. Id appreciate it if you asked your friend too.
thanks for the help
Old Apr 29, 2008 | 10:25 AM
MikeR's Avatar
thanks for the help
Will do.
Old Apr 29, 2008 | 03:05 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Good luck!
The PS reservoir is under the hood in back.
Old Nov 15, 2008 | 05:21 AM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Any one have the part number to buy?? Is it safe to continue using the car for a race this way???? Just started getting the issue at the practice yesterday.... Race is only 12 laps
Old Nov 15, 2008 | 07:47 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
So as to not start another thread about the clutch accumulator, I'll high jack.
Can I do any more damage to the car by not repairing the clutch accumulator right away? My only sympton is the stiff pedal at start up aka "morning wood."
Old Nov 15, 2008 | 08:08 AM
contigo's Avatar
Just called the dealer , said it will go until there is not enough pressure to shift so that is all the damage that can happen, push the part until it is done... And not force the shift, when it doesnt allow to shift you pushed it till its final moment but no further damage.
Old Nov 15, 2008 | 10:09 AM
landjet's Avatar
I have the "morning wood" syndrome but no other symptoms yet after starting the car. Sunset Porsche had a sale on the accumulator and clutch slave last month. I bought both just in case and saved myself $150. Now I have the parts when the time comes.
Old Nov 15, 2008 | 10:14 AM
contigo's Avatar
Should one change both the accumulator and clutch slave when doing it or just the accumulator?
Old Nov 15, 2008 | 03:25 PM
wross996TT's Avatar
Most folks do both as you have already paid for the labor...
Old Nov 15, 2008 | 05:19 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
T2, the guy with 200k miles, has put 5 into his car. My "second" is going up now...so I am switching to a gt2 set up. 1k for the parts. 3-4 hours of labor...but no more accumulator or slave...brake fluid now rather than pentosis. FYI to anyone who doesn't know. Yes, it is more, but the feel per John D is much better for the clutch.
JB
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
magoochi
Aug 23, 2015 05:54 PM
cerbomark
Aug 22, 2015 12:50 PM
