Need to Replace Clutch Slave Cylinder
Old May 30, 2008 | 03:13 PM
mose55's Avatar
mose55 is infamous around these parts
Are you still under warranty? I am having mine done under CPO...
Old May 30, 2008 | 03:34 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
I just did mine (my mechanic did). Ended up doing both the accumulator and the slave...and I found out there is a TSB on the hydraulic lines...air/leaks can cause you to loose the clutch return in the middle of a DE session making one need to double clutch and use the left foot simultaneously to "pull" the clutch back. 3-5 hours+ parts.
The instructor was impressed with the footwork. Hurt like hell.....
Ask me how I know.
All is well now. TSB is 3 circlips on the lines....I had it done by the guys that helped me on the track.....to say thanks. about 1.75 hours of labor...the clips only.
JB
Old May 30, 2008 | 03:38 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
JB, thanks for posting this info. Do you have the TSB number?
Old May 30, 2008 | 03:48 PM
Memory says 3001....check renntech if I am wrong and search on clutch pedal in the 996TT stuff.
JB
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
The Oss
Aug 24, 2015 08:19 PM
oddjob142
Aug 24, 2015 05:49 PM
cerbomark
Aug 22, 2015 12:50 PM
