Intake Plenums, From GMP.....Now Taking Pre-Orders!!!
Old May 2, 2008 | 03:16 PM
GMP Performance's Avatar
Site Sponsor
Intake Plenum Pre-Order
GMP Performance
GMP is proud to announce that we are going to start carrying the IPD Intake Plenums. We are going to order in 5 units to get started but would like to have a couple of them already pre-ordered .
Give us a call to order 888 488 2028 EXT 257
$1,100.00
HP Gains: 30-35 at Mid-Range
The IPD Plenums are a unique design that dramatically increases horsepower and torque by optimizing air flow efficiency. Air flow is managed through a diversion splitter that maximizes air speed into the engine. The charged intake air maintains a higher velocity by replacing the factory plastic “T” intake with a stronger and more efficient cast aluminum “Y” design. This unique “Y” style plenum optimizes flow, improving acceleration and boost response. The new IPD replacement plenum eliminates the turbulent air flow by smoothly splitting and diverting the air flow and directing it towards the cylinders at a much higher air speed. This simple bolt-on plenum upgrade provides dyno proven increases in both power and torque throughout the entire rev range.
Old May 2, 2008 | 03:37 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
what kind of hp/torque gains would you expect with this product? My car is non x-50 with giac ecu, dv's and an exhaust.
How much do is cost to install?
thanks
Old May 5, 2008 | 09:08 AM
Site Sponsor
30-35 Installation is about 3 hours maybe 4. This is something new so we havent installed any on your car, not to say cant do it just could give you an exact amount. we charge $80 per hour
Old May 5, 2008 | 03:59 PM
cfi_luz's Avatar
cfi_luz is infamous around these parts
Do you offer a version for the larger throttle bodies available?
Old May 6, 2008 | 08:21 AM
Site Sponsor
Good question, as far as I know right now, they don't, but we just added them to our site so I will probably have to make a phone call and find out.
Old May 6, 2008 | 04:42 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi... Yes they make a 75mm one that uses a 75mm T/B.... The T/B is avaliable..
Here to assist, Tim
Old May 6, 2008 | 05:02 PM
AboxsterS's Avatar
AboxsterS is infamous around these parts
Has anyone confirmed the performance gains of this intake? I'm going to be going in for a GT610 kit in July and was wondering if this is something that would result in any additional gains...
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
mikerosi
Dec 6, 2018 06:23 PM
orbelo
Aug 30, 2015 12:26 PM
webcarconnection
Aug 30, 2015 11:35 AM
