GT700-Filled with 110 leaded, Sputtering?
Old May 8, 2008 | 10:51 AM
BLKM3's Avatar
BLKM3 is infamous around these parts
I filled my GT700 with leaded 110 fuel for the first time. My car normally runs great off of 100 unleaded. I also have no cats which is why I decided to do it.
When I got i on it, while boosting the car would sputter and hesisitate really hard. Sounds like someone is choking it or the sparkplugs going out. There is at least a 100hp lost in the top 3 gears. The lower gears seem to run ok without the hesitation. Any ideas?
Old May 8, 2008 | 10:53 AM
Divexxtreme's Avatar
O2 sensors? Spark plugs?
Leaded will cause damage to both.
Old May 8, 2008 | 10:58 AM
BLKM3's Avatar
Scott, how are you able to run 116 leaded then?
Old May 8, 2008 | 11:06 AM
I don't use 02 sensors, and I only run leaded in my car for a tank or two at a time before I switch back to unleaded to clean the plugs again.
Since this happened so quickly after you added leaded...I'm guessing it might be your sensors rather than your plugs.
Old May 8, 2008 | 11:09 AM
LUISGT3's Avatar
+1.
How many miles are on the plugs? What kind of plugs?
Old May 8, 2008 | 12:06 PM
BLKM3's Avatar
Bosch FR6 Plugs, about 10k miles.
Right before I filled with 110 leaded, the car was running great, so I am also assuming it's the 02's.
Old May 8, 2008 | 12:09 PM
That sucks, bro.
LUISGT3's Avatar
Cool, I have a friend who runs C16 on his GT700 but changes the plugs every 3,000 miles. You may want to try to change the plugs and see what happens.
Old May 8, 2008 | 04:15 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
plugs - same thing happened to me - put in 110, a few days later, dead plugs. not worth the hassle - stick to unleaded.
- chuck
Old May 8, 2008 | 04:29 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
O2's HATE lead, but I would try plugs first.
Old May 8, 2008 | 04:55 PM
SWATDoc's Avatar
SWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud ofSWATDoc has much to be proud of
I agree, most likely its the O2 sensors, and the plugs are +/- (depending on how much time with the leaded fuel).
Old May 8, 2008 | 05:00 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Had like problems, Run some 93 octane though her....O2's do not like leaded fuel at all. I run 93 @ 20psi on the street....Tim
Old May 8, 2008 | 08:03 PM
sharkster's Avatar
i really think it's that station guys;( (Us Norcal'ers know). There's some weird deposit from their gas too. Gotta change plugs in my white car now...
Old May 9, 2008 | 09:24 AM
WOODTSTER's Avatar
10,000 miles on your plugs? you are kidding right?
Get some plugs in it and maybe try mixing leaded and unleaded.
good luck
MK
COBB Tuning
Nov 3, 2015 08:39 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
