PCCB to Steel Conversion Kit
Old Jul 2, 2010 | 03:28 PM
bsprad's Avatar
bsprad is infamous around these parts
Originally Posted by smdubovsky
I have an X50 w/ PCCBs. x2 on what larry said. 997TT steel rotors front&rear bolt right up for track use. Still use the PCCBs on the street (no dust). Was only an issue long ago before the 997tt rotors came out. The only option before was custom/expensive. Not a problem anymore as there are multiple solutions.
Can you list the part numbers for the 997tt rotors that you use with the pccb calipers?
Which pads do you use? Any issues with the sensors?
Old Jul 2, 2010 | 03:43 PM
vividracing's Avatar
The 997 Turbo part numbers are:
997 351 405 01
997 351 406 01
For a street car, I recommend the Pagid RS29 yellows. They will work great for strong spirited driving. If you want something for full on track, do the RS19 Yellow with the R14 black in the rear.
http://www.vividracing.com/catalog/b...&filter_id=197
Old Jul 5, 2011 | 12:56 PM
jindotli's Avatar
jindotli is infamous around these parts
Hi Smdubovsky,
I have a 03 996 tt x50 with PCCB like yours. My PCCB had sign of damage after I took it to a DE. I have been researching on Internet to find an alternative solution. I am glad you mentioned that 997 tt steel rotors are the direct replacement. I am gonna give it a try. Just a quick question.
Do I also need the a set of pads(of 997tt??) for steel rotors or I can use the the from PCCB?
Thanks!
Old Jul 5, 2011 | 02:47 PM
smdubovsky's Avatar
smdubovsky is infamous around these parts
You need new pads. Don't know if the stock 997tt pads fit, but there are lots of aftermarket pads to work in the pccb calipers. I used a track compound at the track (PFC01?) but it would be totally inappropriate for street driving (dusts & squeaks like CRAZY!)
Old Jul 5, 2011 | 02:56 PM
jindotli's Avatar
Speaking of noise, I don't think PCCB is anywhere better.
Thanks!!!
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
turbosonoma
Aug 19, 2015 02:05 PM
