PCCB to Steel Conversion Kit
Old Jul 16, 2004 | 10:52 PM
Guy's Avatar
Guy
Guy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant future
Following the many problems with the Ceramic discs and the ridiculous cost of replacing, Carnewal (a big Belgian Porsche parts supplier) now do a full conversion kit to convert PCCB equipped GT2s and GT3s back to steel.
http://www.carnewal-europe.com/cpx_p96172.htm
This uses the GT3 front discs and also GT3/Turbo rear calipers/330mm discs, but with yellow calipers to match the fronts.
This entire kit costs less than a single exchange PCCB disc.
Old Jul 17, 2004 | 12:18 AM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
are you running this kit? how does it affect braking performance? How much more do the discs weigh?
Is there anyone in America selling a kit like this?
-Steve
Old Jul 17, 2004 | 02:33 AM
Guy's Avatar
Guy
No- I'm still running my 2nd set of PCCBs, but I'm watching the rotors deteriorate slowly.
Steel rotors offer the exact same braking performance as PCCB, it's been proven a million times (they are fitted to GT3s after all). The only disadvantage is the extra 16kg of weight..........oh and having to clean brake dust again........
Old Jul 17, 2004 | 09:34 AM
FAT-911's Avatar
FAT-911 is infamous around these parts
What pads are you using on the PCCB setup?
Old Jul 17, 2004 | 12:01 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
It was only a matter of time.
Old Jul 17, 2004 | 04:35 PM
Guy's Avatar
Guy
Yellow Porsche Sport Pads.
Old Jul 17, 2004 | 04:53 PM
FAT-911's Avatar
Im running the same on my car and have never had any concerns, however when I track the car I change to the green pads, you may also want to look at some aftermarket cooling ducts etc.
Good luck anyway.
Old Jul 17, 2004 | 11:36 PM
Guy's Avatar
Guy
I've only done one proper track-day in it on the 2nd set of discs, the rest of the 4,000 miles they've had is road use only, albeit it fast road use when driven.
Old Jul 1, 2010 | 09:55 PM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
Bringing this one back from the dead...
Any other options out there to convert PCCB to steel rotors? I am looking at a 996TT x50 with the PCCBs. I'd really prefer the steel rotors. A couple of questions besides the above. Do the steel turbo rotors have the same offset as the ceramics? I am guessing they are not a direct replacement? Can the yellow calipers that come with the ceramics be used with the steel (I believe these are 6-piston v. the red 4-piston)? What about just sticking with the ceramics, what issues am I facing besides heavy cost of replacement (which is how much)? Thank you!
Old Jul 1, 2010 | 10:10 PM
landjet's Avatar
You should be able to use 997 Turbo rotors or aftermarket rotors like Girodiscs if you track. I upgraded from stock 996TT brakes to the GT3 6 piston fronts and 4 piston rears and ran 997TT discs. They were a direct bolt up. Now I'm using Girodiscs on the front, 997TT discs on the rear. Front and rears are 350mm discs.
Old Jul 2, 2010 | 07:14 AM
smdubovsky's Avatar
smdubovsky is infamous around these parts
I have an X50 w/ PCCBs. x2 on what larry said. 997TT steel rotors front&rear bolt right up for track use. Still use the PCCBs on the street (no dust). Was only an issue long ago before the 997tt rotors came out. The only option before was custom/expensive. Not a problem anymore as there are multiple solutions.
Old Jul 2, 2010 | 02:02 PM
vividracing's Avatar
You can switch to the Brembo 2pc option and Pagid pads. This is the same sizing as the 997TT and I run these also. Many PCCB guys switch because of the longevity and simple replacement costs. I would advise on going with the Brembo if you do alot of track days. They will last 3 times longer then the stock drilled 997TT and their McLaren hardware makes only the disk the consumable item and not the hat like others. Check it out - http://www.vividracing.com/catalog/a...rotors&x=0&y=0
Install article - http://www.vividracing.com/forums/pr...-vr-997tt.html
Old Jul 2, 2010 | 02:35 PM
smdubovsky's Avatar
Like I said. Multiple solutions now
Vivid, out of curiosity what do the replacement rotors cost w/o hats? Don't see them on the website.
Old Jul 2, 2010 | 02:51 PM
No problem... When you are ready to replace the Brembo 2pc rotors, you must also do the hardware as it is 1x use only and should not be retorqued. Another difference with the Patented McLaren hardware that others try to simulate.
Front rotors for example are $495/disc and hardware is $80/side.
Old Jul 2, 2010 | 03:13 PM
bsprad's Avatar
bsprad is infamous around these parts
Here's a relatively affordable solution to remove the pccb while retaining all Porsche parts. This is likely the kit I'll go with when I have any issues with mine.
http://www.suncoastparts.com/product...=996ttceramics
