Anyone have a set of K24's for sale?
Old May 14, 2008 | 08:57 PM
Small Shrimp's Avatar
Small Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to allSmall Shrimp is a name known to all
I sent Roadster a message as well.
Also talking to Kevin at Ultimate
Old May 14, 2008 | 09:23 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I've heard of zero clearance turbos but I'm not sure what advantage they have over normal turbos. Forgive my lack of knowledge, I'm coming from the 930 world. Would someone explain the benefit of zero clearance turbos? Thanks
Old May 14, 2008 | 09:45 PM
ard's Avatar
ard
They are more efficient.
This translates into better performance. Less lag, more boost, better control.
If you can imagine, the spinning blades inside a turbo have to have some space or clearance between the vane or blade and the body- this space means that some air will 'leak' past and not actually spin the turbo.
With a zero clearance, they epoxy coat the inside, then assemble and spin. the spinning blades remove just enough epoxy to allow the blades to turn- and leave, just about zero clearance between the blade and the wall (now epoxy coated).
Search is a friend...lots of discussion on these.
A
Old May 14, 2008 | 10:15 PM
I have K24s with 3K miles for sale.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 15, 2008 | 05:25 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
A
+1
So many options....
Old May 15, 2008 | 08:03 AM
Originally Posted by MMAD28
How much ?
$2250+shipping
9.66
click to view
Old May 15, 2008 | 09:52 AM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
Originally Posted by John D
Here's some food for thought - You may be able to have yours rebuilt into k24/18G's for less than a set of new K24's. Then put your savings toward the software upgrade and you will have yourself a nice upgrade for roughly the same money.
If you are doing that (something I am contemplating) aren't you pretty much putting more power down than the stock clutch will handle, and are also walking in to a clutch upgrade due to that and at how much $$??
Old May 15, 2008 | 09:57 AM
unvmy996's Avatar
Originally Posted by MARKSKI
$2250+shipping
good deal...
Old May 15, 2008 | 11:47 AM
Originally Posted by unvmym3
good deal...
Agreed!
JB
Old May 15, 2008 | 12:34 PM
wross996TT's Avatar
Tim, the guys have given some great advice...good luck with your decision. BTW, what happened with your "new-to-you" K24?
Old May 15, 2008 | 12:36 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Probably, I guess you WOULD have to be prepared for that, however the stock clutch may last a year or more, so you can wait and see how long it holds up.
Labor is about $800.00. Parts are about $1,600.00, I think (pressure plate, TO bearing & disc)
Jul 29, 2019 11:13 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
racerbvd
Feb 11, 2016 12:07 PM
BlackMarketRacing
Dec 8, 2015 01:49 PM
BlackMarketRacing
Dec 3, 2015 10:46 AM
