Is my TT flashed already?
Old May 15, 2008 | 10:34 PM
derm's Avatar
derm is infamous around these parts
I bought it from a local dealer and it is said to be stock. But I find that mine seems to be faster and more responsive than my friends' TTs. As I intend to have my TT flashed, it will be a waste of $$ if it has been. Is it a simple way to test / tell whether my TT has been flashed? (I can't contact the previous owners).
Thanks!
Old May 15, 2008 | 10:42 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Are you running K16 turbos. You need to find out what turbos you run. If you Dyno the car and find out that you are putting out 400 plus rwhp or 390's on AWD then it is stock, anything more than these numbers would be flashed. Dyno will show the facts.
Old May 15, 2008 | 11:02 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Just check what boost are you running on. An unflash car should be around .7 Bar. A flashed car should be around 1.0 Bar for lower stages.
Old May 15, 2008 | 11:15 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
agree, check on your boost, if it been flashed, it should hold at 1.0 or more.
Old May 16, 2008 | 12:56 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Make a dyno run and you''ll find your answer.
Old May 17, 2008 | 02:14 AM
art4iza's Avatar
I agree with all comments. Boost is another equation here. Let us know.
Old May 19, 2008 | 08:23 PM
derm's Avatar
Thanks all for your comment!
I think my TT is still virgin, as the highest boost I could ever see is a transient 0.7 only and most of the time 0.4-0.5. I'll get it flashed and wake it up.
Cheers!
Old May 19, 2008 | 08:26 PM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
Cheers!
If your seeing .4-.5 your car is sick.
Your leaking boost, or in limp mode.
Seeing how you prob don't have any mods, you're prob leaking boost.
Thats if your only seeing .4-.5 while the pedal is to the floor.
Old May 19, 2008 | 09:04 PM
Turbo Fanatic's Avatar
Agreed. You should see .7 pretty much any time you're flooring it. Make sure you push past the carpet
The upside is that you can easily be running 1.0 BAR! Looks like you have a good 80-100 HP waiting for you with an exhaust and flash.
Old May 20, 2008 | 08:31 PM
derm's Avatar
When I floor it hard, it gets to 0.7 but I do not floor the pedal too often. In DD, I normally press it half way down and it gets to .4-.5 .
Old May 20, 2008 | 09:37 PM
MY996TT's Avatar
That sounds about right for a stock TT.
Oct 6, 2015 06:13 PM
Oct 2, 2015 02:23 PM
