Does a GT2 Bumper fit on a 01 996 turbo?
Old May 24, 2008 | 01:31 PM
N1_kT's Avatar
N1_kT is infamous around these parts
im a new to the Porsche scene and i just aquired a 01 996 turbo and wanted to change the bumper to a oem 02 gt2 bumper. My question, is it a direct bolt on?
Old May 24, 2008 | 02:08 PM
N1_kT's Avatar
can anybody help?
Old May 24, 2008 | 02:20 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
An OEM GT2 bumper will need radiator relocation to fit ....I think I have seen estimates of around 4K to do the whole GT2 conversion on a turbo to OEM specs with correct Porsche parts.
Old May 24, 2008 | 02:27 PM
N1_kT's Avatar
thanks for the reply, do you know what kind of parts would i need if i were to do it myself?
Old May 24, 2008 | 02:37 PM
KPG's Avatar
KPG
I have the PET parts catalog on disc that shows the exploded view of the GT2 front end and there are many parts needed. I have no clue what parts can or cannot be reused in the conversion. You best bet is to call someone like Suncoast or Sunset Porsche since they specialize in Porsche parts sales at little over dealer cost. They will not rape you on parts. They are generally speaking the cheapest out there and they are knowledgeable. Just tell them what you have and they will tell you what you need......good luck
Old May 24, 2008 | 02:48 PM
N1_kT's Avatar
as far as fitment with the 01 996 turbo headlights, hood and fenders its the same?
Old May 24, 2008 | 06:17 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
You can buy an aftermarket that needs little no no modifactions,
Yes it will fit on an TT...the same on as the GT2.
They are the same car.
Old May 25, 2008 | 04:08 PM
liquidcool's Avatar
liquidcool is infamous around these parts
I wanted to do an aftermarket gt2 front bumper.. My indy mechanic who has never steered me wrong wouldn't do it. He claims the aftermarket ones (which are $1500 or so) are fiberglass and won't have the same finished quality as the Porsche parts which are kevlar/pvc or whatever they are. He would only let me do it with OEM parts and the entire conversion was going to be around $5k with parts after moving the radiators and plumbing.
Old May 25, 2008 | 05:19 PM
kilrgt's Avatar
You need to see one yourself and then make that choice, I too am a big fan off OEM, but that didn't stop me from going with some Gemballa and tech-art parts.There really are some smaller guys out that that make a good product. Misha for example makes good quality aftermarket parts, I had a GT2 wing by Misha on my C2. Don't let your indy steer you wrong, maybe he is un aware of the quality thats out there now....and maybe he id afraid of things he doesn't know.
Old May 25, 2008 | 06:00 PM
efxautosport1's Avatar
efxautosport1 is infamous around these parts
+1 :d
Old May 25, 2008 | 07:04 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
the problem with the aftermarket GT2 front isnt the fitment/materials..it's the fact that you lose all of the proper air flow. Because you're not moving the center radiator etc., you're not gaining the advantage of the OEM GT2 aerodynamics, and you're losing the effectiveness of the stocker.
Old May 27, 2008 | 01:36 AM
N1_kT's Avatar
has anybody on this forum done this conversion themselves that can help me out?
Old May 27, 2008 | 03:53 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
I have a OEM GT2 front bumper and did not purchase the brackets to relocate the radiator. It has been on for 2 years and I have not had any problems. Air temps have not increased at all. No adverse effects. It was a simple bolt-on.
Adam
Old May 27, 2008 | 04:08 PM
pnoob2's Avatar
pnoob2 is a jewel in the roughpnoob2 is a jewel in the roughpnoob2 is a jewel in the roughpnoob2 is a jewel in the rough
What color is your turbo? I have a OEM GT2 front bumper and proper radiator ducts and brackets, Im currently selling my car, and if it does not sell in a week I will be parting. Maybe we can do a swap plus cash. Im in socal and my car is jet black.
Old May 27, 2008 | 07:44 PM
OneLap996TT's Avatar
OneLap996TT is infamous around these parts
I did the GT2 nose conversion to my car over three years ago. I used all OEM parts. It's not for the faint of heart but it is doable.
The turbo uses a dual loop cooling circuit to the three radiators where as the GT2 uses a single loop from right radiator to center then to left. In addition, the center rad uses different mounting brackets. I found it interesting that one of the GT2's brackets was identical to the turbo's, but only used upside down! I used a combination of GT2 hoses that I modified to keep the turbos dual coolant circuit instead of changing the center metal coolant pipes to the GT2's pipes. I don't remember the costs.
I spent hours doing the conversion myself so I didn't have that expense, but I did it right the first time and it's paid off. I've had no problems at all.
Mark
