Greddy Diy Install
No. No photos. But it was fun! Best advice... bring a friend!!! You'll need him if nothing else for the 5 Bar FPR install. We removed the air pump on top and all the turbos, Intercoolers & all the plumbing on the bottom. My Buddy pushed the FPR clip in from the top while I pushed the regulator in and held it with a long breaker bar. I'm not completely together as I'm waiting for gaskets from my local Porsche store. I'll let everyone know more when I'm finished with the job.
Several guys have asked me to explain my experience in installing my Greddy, as the instructions are written for those with some knowledge of the cars. No disrespect intended to Todd, as the directions are perfect. However, for those of us who are a little less "seasoned" with the square end of these cars, here goes....
The factory piece has three hoses on it and a wiring harness. You can get the factory piece out of it's holder...no problem. The three hoses are key and how I did it was, in looking at the hoses, realized there is one in the front, one on the bottom and one in the back. Armed with that novice based strategy, here is how I did it:
NO Front hose
COM Bottom hose
NC Back hose.
Things I bought and where:
2 sections of 25' each of vacuum line from Napa
3 male-male brass barbs for splicing vacuum line [Lowes]
1 90 degree brass vacuum line fitting that goes into the Greddy [Lowes]
1 three way brass Tee [Lowes]
So now I have the factory gray solenoid popped out of its bracket and have removed the hoses and wiring harness.
Next I spliced in 3-4 inches of new hose onto each of the 3 factory hoses using the brass barbs to give me some room to mount the new solenoid. I also wire tied all the factory fittings as two of them are mated to hard pipe and had no clamp on them. Just hold them from the bottom, slide the hose down tight and double wire tie each connection.
Once I had the splices in and double wire tied, I plugged the tag ends into the new solenoid, using the 90 degree for one of the connections. It doesn't matter which one and you probably don't need a 90, but in my case it just made it easier to get them all buttoned up without any hint of a kink in any of the three lines.
Manipulated the Greddy into a "comfortable location and wire tied the whole thing into place. Done.
Now to the fpr vacuum line. Using one section of new 25' vacuum line from Napa and Mikelly's GREAT tutorial for replacing a 5bar, I removed the air pump and the vacuum line was right there. I used a brass three way I bought from Lowe's for this to make the connection. Once you get it in place, route the hose [w/ the air pump still off so you can see!] back towards the harness.
So now you have 25' of vacuum hose and a wiring harness together in the engine bay. Crawl under the car and follow Todd's directions for snaking your line up through into the bay. Tape them up and pull them through, wire tieing them as you go. Not too tight on the ties- don't crush the vacuum line.
Now you have the harness and the vacuum line hanging under the car. If you are putting your Greddy anywhere in FRONT of the arm rest console, now would be a good time to splice some wire into the harness.
Once that is done. route the vacuum line and harness up, following the ebrake line, into the tunnel where the drive shaft is. Just in front of where the ebrake and shift cables go through, in the very top of the tunnel and directly above thye drive shaft AND COMPLETELY OUT OF SIGHT, run your hand up there and you will feel a rubber grommet. Pull it out.
Route your lines up through the hole and please make sure to wire tie them all the way up to where the ebrake goes through as you certainly do not want them getting caught in the drive shaft!
The rest is pretty straightforward. Route the lines where you want the thing mounted and getr' done. I found what i believe was an old factory radio harness that was not being used for my power. 12v switehed is green/brown and ground is brown. It is a flat 4 or 5 pin plug. Todd's directions use the windows for power.
That's it. Enjoy!
NO Front hose
COM Bottom hose
NC Back hose.
That's it. Enjoy!
thank you
Bill
