Keyless Remote
Old Jun 1, 2008 | 09:42 PM
Turbo Fanatic's Avatar
Keyless Remote
My remote seems to be working sporatically. I have replaced two batteries and don't have another key.
Sometimes it works if I get within a few inches of the receiver, sometimes a few feet away from the car and sometimes not at all.
The red light on the keyfob always comes on, but the light in the dash doesn't blink when it's not working.
Any ideas?
Old Jun 2, 2008 | 03:02 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
I guess it's a problem with the car reciever then...
Old Jun 2, 2008 | 06:42 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Mine does this when the car sits for over 5 days. It goes into a security mode and must be opened with the key.
Old Jun 2, 2008 | 10:30 AM
rwilliamtaylor's Avatar
rwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of light
Mine stopped working, but I didn't try holding it close to the receiver.
I manually opened the door with the key, then all OK. It wasn't after 5 days, it was after 5 minutes, but it worked.
Old Jun 2, 2008 | 03:16 PM
porschedude996T's Avatar
porschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really nice
Take the Key Fob apart and see if there is any fuzz or dirt on the internal switch contacts. Spray it out with some canned-air.
Old Jun 2, 2008 | 08:38 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
I've noticed when I park in certain areas the remote doesn't work. I always put that down to local RF Interference.
There was a mod the dealers did with the earlier 996 series to increase the range (rerouting the antenna wire up the door pillar I think). I think It was a service note (or whatever Porsche call them).
I sometimes find with RF remotes, you hold them up to your neck the range increases (using the body as an antenna).
Old Jun 2, 2008 | 08:41 PM
Danyol's Avatar
Tsb 9662
Old Jun 2, 2008 | 10:08 PM
Thanks guys. The TSB is probably the culpriy, but why is it getting worse over time even with new batteries in the remote?
BTW I know the 5 day shutoff thing. This definitely is not related. Just poor or no reception using the keyfob.
Old Jun 2, 2008 | 11:11 PM
DYL 911's Avatar
DYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to all
i'm having the same problem recently, please let me know if u find any info
Old Jun 2, 2008 | 11:51 PM
Have you replaced the battery in the keyfob?
Old Jun 2, 2008 | 11:59 PM
DYL 911's Avatar
yep, the red light on the fob flashes normally
i used to get closer to the center of the windshield before and it would work
now it never or rarely works and i have to open it with the key
if i don't turn on the ignition within 7 seconds the alarm goes off or if i open the passenger door before the 7 seconds it goes off
Old Jun 3, 2008 | 12:43 AM
my exact issue. just cropped up, and seems to be getting worse.
Old Jun 3, 2008 | 01:49 AM
Frög's Avatar
Frög is infamous around these parts
Dont' meant to thread jack..
I have no range whatsoever.. anything i can do to fix this?
Old Jun 3, 2008 | 06:32 AM
Danyol's Avatar
TSB 9662, although I don't see the TT listed as an applicable car (996 C,996 C2, GT3). Not sure what is different about the TT wiring harness?
Old Jun 3, 2008 | 09:12 AM
Found this about the Boxster. Seems that the antenna is too short and extending the wire by 130mm it is the fix: http://boxster.wikia.com/wiki/Procedure
Rennlist has all TSBs listed, but I don't remember my login.
Can someone clip and paste it please?
