Check Oil Failure Indicator
Old Jun 2, 2008 | 09:04 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Got a message that the check Oil Indicator is failing.......basically can not read my oil levels, right out of nowhere too in the middle of driving just got the message. Anyone have any experience with this? and know what could be causing this?
Old Jun 2, 2008 | 09:51 AM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
During a recent drive home from a day at the track recieved a message, "Indicator failure". At the same time the oil pressure gauge was bouncing up and down before dropping to zero. Car felt fine so, I didn't stop.
Dealer replaced faulty oil pressure sending unit.
Old Jun 2, 2008 | 10:03 AM
LiNks's Avatar
It was right after racing that it happend to me too. Car feels perfect, guess I just have to get the unit replaced too. Car is covered under CPO until July better get there quick haha.
Old Jun 2, 2008 | 12:28 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
I have an intermittent failure of the sensor too. About once every 6 months the failure indicator comes on. I shut it down, reset the codes, and everything is fine. Oil level check and pressure gauge work fine too. Very weird, but I'd try resetting the code first.
Old Jun 2, 2008 | 01:14 PM
unvmy996's Avatar
my oil pressure gauge drops to zero all the time the goes back up... but i dont get any failure warnings.
Old Jun 2, 2008 | 02:13 PM
LiNks's Avatar
I called the dealer and they said that if the whole thing needs to be replaced then it is covered under warranty, they then said if the unit can be fixed ex) wire is loose or whatever then they are going to charge. I think I should just reset it to see if it comes back before I bring it in.
Old Jun 5, 2008 | 06:44 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Can you do this with a generic OBD2 reader...san buying a durametric?\
Got message....meter seems fine afaict.
TIA
JB
Old Jun 5, 2008 | 06:47 PM
DNugget991GT3's Avatar
links
same thing happens to my car occasionaly
i dont worry about it
give more throttle and it all goes away
Jul 29, 2019 11:13 AM
mrgylex
Oct 20, 2015 03:45 PM
hacellular
Aug 31, 2015 08:34 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
