Bars
Old Jun 2, 2008 | 08:25 PM
jgx50's Avatar
jgx50 is infamous around these parts
Bars
You guys with the k24/18g turbos how many bars are you hitting on third gear and what program are u running.
Old Jun 2, 2008 | 08:27 PM
unvmy996's Avatar
1.1 on pump, running proto software , and i have the greddy ebc to crank it up to 1.3 on race gas.
Old Jun 2, 2008 | 08:34 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
1.05bar on pump fuel and 1.18bar on race. I'm running Proto software. Like unvmym3, I have a Greddy boost controller, so I can set the boost wherever I want it.
If you don't have a boost controller, you should consider one...it makes adjusting boost so easy.
Old Jun 2, 2008 | 08:40 PM
jgx50's Avatar
Should i be worried if im running consistently 1.3 bars on 95.
Old Jun 2, 2008 | 08:42 PM
unvmy996's Avatar
yes , you really dont want to go over anything 1.1 on pump , do you havea boost controler ?
Old Jun 2, 2008 | 08:43 PM
What software do you have? Do you have a boost controller?
That seems a bit high to me, but you should check with your tuner.
Old Jun 2, 2008 | 08:45 PM
jgx50's Avatar
I dont have a boost controller. softronic
Old Jun 2, 2008 | 08:49 PM
I was told not to run over 1.1bar on pump fuel, but that is 93 octane. On 95 you may be able to run a little more boost, but 1.3bar seems too high to me. I don't even run 1.3bar on race gas....
Old Jun 2, 2008 | 09:18 PM
unvmy996's Avatar
yup , you should invest in a boost controler , 1.3 is way to high for 95 1.1 is the max on pump. i would talk to you tuner get a new file .
Old Jun 3, 2008 | 05:27 AM
y996t's Avatar
y996t is infamous around these partsy996t is infamous around these parts
I run 1.5 on race gas with Proto software with no boost controler its like a rocket on wheels
Old Jun 3, 2008 | 07:13 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I run 1.0 bar on 109 octane race gas. Advance the timming! Works well.
Old Jun 3, 2008 | 07:16 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
1.2 bars here on pump, car runs great. (I do mix in a couple gallons of 103unl from time to time to keep things safe).
Old Jun 3, 2008 | 07:31 AM
996twin_sc's Avatar
996twin_sc is infamous around these parts
Proto tune and I run 1.1 on 93
Old Jun 3, 2008 | 09:13 AM
WOODTSTER's Avatar
Good GAS IS YOUR Friend and pump gas "can be" your enemy.
I pull consisten 1.3 to 1.4 bar on MS 109 (105 octane unleaded/$10 per gallon)
On pump I do not like more than 1.1 bar personally.
I have been boosting this way thousands of times.
MK
