What's Up With My 996TT?
Old Jul 5, 2008 | 12:55 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Hi guys I'm new here and am in need of some help
Whenever I start-up my 996TT it makes a strange noise from the engine compartment for 3-4 seconds "BRRRRRRRRRRRRR"
Imagine blowing down a length of plastic piping - that's the sound
It seems to stop when I pull away
Someone told me it could be a leak somewhere, and suggested I check the boost pressure
I'm not too sure what's the best way to do this
But - if i drive slowly in 2nd gear then "floor it" until the redline I get 0.4Bar
I get the same reading if i do this in 3rd and 4th gear too
Is the boost pressure meant to be higher than that?
Does this sound like a leak from somewhere?
BTW - car is completely stock to my knowledge (only owned it 5 months)
Thanks in advance
Ant
Old Jul 5, 2008 | 01:32 PM
I you have a blown hose.... one that came off maybe...
just take it to a shop have someone that knows take a look at it... chances are they will find something else as well.
You need to pressure test the car... fix the leaks... ALL the leaks...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 5, 2008 | 02:06 PM
MariusL's Avatar
MariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the rough
stock 996 TT should see higher boost, 0.6-0.7bar if I'm not totally wrong
Old Jul 5, 2008 | 02:19 PM
ant_8u's Avatar
I also thought boost should be around 0.6-0.7
Can anyone confirm this?
Do you think a loose pipe is the cause of both the Low pressure and the noise?
I've heard the DV's are prone to failing - could this also be one of the causes here too?
Old Jul 5, 2008 | 02:31 PM
Turbo Fanatic's Avatar
.7 bar for standard
.8 bar for X50, GT2, Turbo S
Do not drive your car hard until you get it checked out. If you have a leak, your turbos could very well be spinning beyond the design limits trying to reach .7 bar.
Old Jul 5, 2008 | 02:53 PM
ard's Avatar
ard
Originally Posted by ant_8u
Probably... imagine a split rubber hose- air leaking out, causing the rubber to vibrate. BBBRBRRRRRRR... Or the DVs are leaking and you are hearing that?
Once you know what to look for it would be pretty easy to inspect...
A
Old Jul 5, 2008 | 03:39 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Thanks in advance
Ant
Does your car throw any dashlights? I had a similar issue when one of my boost hoses had a tiny hole in it because it was cracked (threw a CEL light for me). Hopefully the leak test will take care of things for you.
Old Jul 5, 2008 | 03:43 PM
ant_8u's Avatar
Originally Posted by ari
.7 bar for standard
Good advice - thanks
Old Jul 5, 2008 | 03:48 PM
ant_8u's Avatar
There are no dash lights showing up
Just a strange sound and a loss of boost pressure
Where abouts are the DV's? - are they part of the turbo unit itself or are they connected to them? (i'm still learning - turbos are new to me)
I ask because - If the DV's need replacing and I decided to upgrade to k16/16Gs would that take care of the DV's? or would they need sorting separately?
Old Jul 5, 2008 | 04:10 PM
ard's Avatar
ard
Separate. Look at this if you want to locate the DVs
http://www.turbo911.com/showthread.php?t=287
Old Jul 5, 2008 | 05:16 PM
ant_8u's Avatar
thanks ard - very interesting read
i have been looking at the turbo upgrade kits and have seen the external wategate and pipe coming off of the header pipes
what's the reasoning behind this?
is it just for the k24s - or could i put these headers and wastegates on the k16Gs?
I promise after this I will learn more about turbochargers and their workings before asking any further questions I could easily find had i done a bit of research first
Old Jul 6, 2008 | 08:17 AM
ant_8u's Avatar
I've just ordered some new Forge DV's - the adjustable ones
How long would you say it takes to replace them?
And whilst I'm at it is it worth changing/upgrading the F pipe - or is it fine as it is?
Old Jul 6, 2008 | 11:55 PM
ard's Avatar
ard
People will say to replace it. I'd say replace it if it needs it.... what year? after 4-5 years stuff can start getting brittle, so perhaps new will be called for. Indeed, you may already have a split hose somewhere.
In the external wastegate stuff- plenty of other simpler options for you- read up.
I'd say you want to take a 'personal inventory' as to what YOU want....what are you going to do with the car (track, just street/drives, etc) and what level of performance you are seeking. Do you want to just optimize the basic platform, do you want modest upgrades- or anything goes but WITH CURRENT INTERNALS, or do you want a monster. What is your budget.
Took me about an hour to replace the DVs...
A
Terminator
Oct 7, 2015 08:12 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
gjpearce
Sep 30, 2015 04:26 AM
Fullthrottleguy
Sep 28, 2015 03:19 PM
