Radiator problems
Old Jul 10, 2008 | 08:43 AM
4G64T's Avatar
4G64T is infamous around these parts
Radiator problems
Since I refilled the coolant with approx 2.5Litres of coolant after I got a Low Coolant Level warning, I check my coolant level every weekend after I run the car when the engine is cold. I have to refill approx 200mls every week (when the engine is cold). I got a pressure test on the system and there seems to be no problems. I now notice small amounts of coolant near both front tires on the ground.
Is there an overflow at these points? Am i putting too much coolant in when the engine is cold? Can there be a problem with the thermostat?
Old Jul 10, 2008 | 09:09 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
Check the cap and see what the part number ends in
Old Jul 10, 2008 | 10:27 AM
Westy's Avatar
Westy is infamous around these parts
It's a sure bet that the front rads want changing. There are 3 rads on the 996turbo.. Centre and then one either side.. I would replace all 3 at once as well.. Costly but its a common fault..
Old Jul 10, 2008 | 10:57 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
Careful. In my case, after the quarter sized puddles came the entire radiator separating at about 90 mph.
Old Jul 10, 2008 | 11:07 AM
4G64T's Avatar
Whats the cost of the 3 radiators?
Old Jul 10, 2008 | 11:49 AM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi.. We have seen this before......Most times it is the head gasket leaking under boost! I will pm you! Tim
Old Jul 10, 2008 | 12:07 PM
Westy's Avatar
Please tell me I'm missing something here... OK Reading the first post it mentions water near both front wheels... Yep front wheels... Now as I understand Porsche never put an engine in the front did they??
Front Rads for sure mate... Get them check and replaced asap before they go pop...
Old Jul 10, 2008 | 01:50 PM
Staff@RPM's Avatar
[quote=Westy;1943393]Please tell me I'm missing something here... OK Reading the first post it mentions water near both front wheels... Yep front wheels... Now as I understand Porsche never put an engine in the front did they??
Hi... Have to love the humor....We have notice that the 996 TT will let combustion gases past the head gasket and not let the water in . I would check if you have anything floating in or on the bottom of the tank.... I hope I am wrong! 1.1/2 bar and a little bad gas ( lower then 94/3) and you run a good chance of getting some detonation and that head gasket is going to pay the price! Tim
Old Jul 10, 2008 | 02:20 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
http://en.wikipedia.org/wiki/Porsche_924
Old Jul 10, 2008 | 06:10 PM
4G64T's Avatar
Tim, nothing floating in the tank and just got the oil changed and no mention of any water in the oil. Also the leakage is found close to the front tires.
Old Jul 10, 2008 | 08:14 PM
Staff@RPM's Avatar
Hi, I have lost one hose with a tee in it.. I will PM you the price of the radiators...Tim
Old Jul 11, 2008 | 12:26 AM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Originally Posted by NineNineSixTT
But that's not a Porsche, it is an Audi!
j/k
Here are some other front engined Porsche cars for the record.
http://en.wikipedia.org/wiki/Porsche_928 My favourite in GTS
http://en.wikipedia.org/wiki/Porsche_944
http://en.wikipedia.org/wiki/Porsche_968 My other favourite in Turbo RS.
Hijack out!
Old Jul 11, 2008 | 12:36 AM
itacud's Avatar
itacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the rough
I just bought one...
Sunset Imports has the side radiators for 370 each.
Old Jul 11, 2008 | 03:57 AM
turbo73's Avatar
turbo73 is infamous around these parts
I had the same and got them changed before a driving holiday covering 2,500 miles. They weren't dripping, but were producing that horrible 'radiator' smell when we got out of the car. Also, I was given the option to only replace 2 as the middle one looked OK, but changed all 3 given the luck I've had of late.
It's a common fault apparantly caused by all the crud collecting in the front and slowly corroding the radiators, and I was told need changing every 5-6 years depending on useage and conditions etc.
Old Jul 17, 2008 | 11:38 PM
4G64T's Avatar
Finally found out that the left and right were both leaking. The middle was OK but decided to replace all three as well as the coolant hoses in the engine. Better to be safe than sorry.
spitfun
May 7, 2020 08:00 AM
Pharris409
Nov 1, 2015 06:57 AM
gadgetman
Sep 10, 2015 03:29 PM
