Big HP Kits, I'm just not getting this!!!
Old Jul 15, 2008 | 12:29 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Originally Posted by Seal Grey Matte
Good news: your math is a bit off. You don't just multiply by 1.2.
The equation is (stock awhp)/(stock hp) = (modded whp)/X.
You then solve for X (modded crank hp).
Assuming your stock car would dyno at 325 awhp (which is what I usually see on a mustang), then the math is:
325/416 = 505/X
X = 646
Still though, 646 crank on race gas is a far cry from 700 on pump.
I bet you'd get 700 on race gas on a dynojet though.
FYI, stock cars dyno at 390rwhp on a dynojet.
Thank you for the correction.
On that dyno day, we ran a stock 996t on the mustang dyno, and got 338. So i believe the true equation should be:
338/416 = 505/x
If my math is correct, 623... ?
Originally Posted by LUISGT3
What did your current set up dyno at?
One moment, as i try and locate a dyno sheet. I would rather post a dyno sheet, than throw out numbers
Old Jul 15, 2008 | 12:31 PM
A case in point:
I have seen one tuner show a dyno with 500rwhp vs. 600 rwhp from another tuner on the same turbo...
Things that make you hhmmmm
markskki
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 15, 2008 | 03:21 PM
wross996TT's Avatar
The measurement systems are poor (contain a lot of measurement uncertainty), so wide fluctuation is to be expected. This is why many are more interested in 60-130 runs and the like. BTW I'm calling mine a 670 kit
Old Jul 15, 2008 | 04:38 PM
Divexxtreme's Avatar
Originally Posted by NineNineSixTT
My SG700 only made 505awhp with sunoco 104:
505 x 1.2 = 606 ??
SG700 = 606
I know of another SG700 who dynoed below 505 with 104
Mustang Dyno.
The general rule of thumb for these cars is 18.5% loss for AWD, and 12.5% loss for RWD. So, if your car made 505 awhp..that puts crank HP at around 619 or so (505/.815).
That said, not all tuners are the same..so Brand X's XX700 cars may make less HP than Brand Z's ZZ700 cars....etc...
IMO, the best way to know how much power your car is really making is to use 60-130 times and trap speeds from 1/4 mile runs. Not dyno numbers.
Old Jul 15, 2008 | 04:52 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I agree, but the whole point is surely if the vendor advertises a 700 kit it should be a 700 kit, give or take 15/20 brake, after all that's what you pay for, plus it doesn't confuse the **** out of the customer.
A fek it, it must be me!!!
Old Jul 15, 2008 | 04:59 PM
I agree wholeheartedly.
Old Jul 15, 2008 | 05:00 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
The only problem with this is that the drivers ability is a factor into and not a factor on a dyno.
Old Jul 15, 2008 | 05:23 PM
With 1/4 mile times, the trap speed isn't affected by driver ability too much...unless the driver is absolutely horrible. With 60-130 times, you can use the driver's shift times to compare with the shift times of other drivers.
No method is totally fool-proof...but IMO, dynos have way too many "unknown" variables to consider them as accurate as real-world acceleration data like trap speed and 60-130 times.
Old Jul 15, 2008 | 05:30 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
700 kit usually means 700hp to crank on race gas measure on dynojet. Also at reasonable ambient conditions and proper cooling fan. And the car should have all supplemental hardwares.
Old Jul 15, 2008 | 05:31 PM
Dr_jitsu's Avatar
It is true that a good amount of skill is involved in 60-130 times. However, it is the sort of test that everyone can practice on a fairly regular basis (unlike 1/4 mile where you absolutely need a track). Even if you cannot find a stretch of "Mexican" highway lonely enough to allow you to hit 130, everyone can do a hard third gear pull and practice speed shifting into 4th which is the major skill set needed for a decent 60-130 time.
Thus the 60-130 is THE standard to measure acceleration. To illustrate, there is nearly a full 2 second difference between my 600 rwhp M3 and my 600 rwhp GT2.
Old Jul 15, 2008 | 05:37 PM
robertp's Avatar
Is this due to the fact that you can shift one better than the other?
Old Jul 15, 2008 | 05:48 PM
Dr_jitsu's Avatar
I can shift the manual (Porsche) faster but the big difference is in torque and powerband. The M3 only makes 450 torque and the peak powerband is betwen 6.5 and 7.2 K RPM's.
The Porsche makes peak power from 3.9K to 6.5 k.
Old Jul 15, 2008 | 06:02 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
And then you gotta figure in the wildly varying money the "tuners" charge to get 7 second 60-130 times. I'd venture to bet there is a $20,000+ difference between the least and most expensive 7 second car. Although, and in all due fairness, the 30K car will have some snappy stickers and badges whereas the sub 10k car will simply look.....well......stock. Go figure.
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
