Braking better
Old Jul 18, 2008 | 11:24 PM
seattle_sun's Avatar
seattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really nice
Originally Posted by f1crazydriver
Unv, i know the question is not regarded towards me BUT i'll say paigd yellows are awesome. They have goood brakeing when cold. Once up to temp people who ride in my car while when i go to mtn runs say the brakes brake their necks and they feel like they are being launch out of their seat. Do fluid and pads and you will see a world of diffs. I run pagid's i did orange and they were great but not that initial bite i wanted for my style of brakeing- so i went to the 29s yellow. The stock calipers are good with good pads. Stock pads are a joke. I keep the yellows all the time, the car is my DD.... i don't mind the brake squeak- they do squeak quite a bit.
I ran the yellows for track days, but they chirp quite a bit when cold!
My guess is that you live in one of the warm states, because I found the yellows to be lacking when it was cool outside and the brakes were cold.
Old Jul 18, 2008 | 11:28 PM
MGS996TT's Avatar
MGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to behold
What's your thoughts on the Motive Power Bleeder? Best supply source?
Cheers
boss351 wrote :The AP brake lines are a breeze to install, just need line wrenchs (10 and 11mm). Fluid was easy with a Motiv Power Bleeder (and 4 bottles of Motol RBF), pads again easy, bedding no biggie.
Old Jul 19, 2008 | 06:20 AM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
Originally Posted by MY996TT
The next mod will be those behinds the brakes... coilovers.
That is evil! They are what I would like for sure, but being completly honest now.... I only have 3 track days under my belt. I have pretty well been the fastest in my group at each outing but I know that doesn't mean the car is perfect, but it has been handling great within my capabilities. The tyres and brakes were noticeably the weakest link in the chain for me and those issues have been fairly well dealt with.
It is also like power, before this last track weekend I was fairly hot to flash the car (and hence need a new clutch in the process) but at the track all I could think about was what the heck do I need more power for, just to shoot down the straights a little faster?? I was passing more powerful cars on the track (and see that all the time), for me the money would be better spent on coil-overs and sways as you say, leave the power mods till last...
Old Jul 19, 2008 | 06:42 AM
Mikelly's Avatar
I do a lot of track days... Some of you have read and seen my exploits here... Here is my "formula" for the proper OEM 996TT setup...
Pagid Yellow pads all around
Motul RBF/ GS610/ AP Racing/ brake fluid bleed before EVERY event
GT3 RS cooling ducts.
I use the Motiv brake bleeder and I can bleed my brakes in 30 minutes trackside. I do NOT use the motive to pull the fluid into the system, but only as a pressure provider for forcing air out of the system. Once done with bleeding the air out, I add fresh fluid from an un-opened new container.
I pull air out of my brake system every single time I bleed it. No exceptions. So if you're tracking your car, you need to bleed the brakes thoroughly before each track weekend, and be sure to be patient. I tap on the calipers with a small rubber mallet to help move the bubbles out when bleeding circuits...
I've since moved on to the GT3 caliper/ 350MM rotor up front and the 997TT rotor in the rear, but the rest is the same...
These pagid yellows had 9 days on the fronts and 15 days on the rears, plus about 6K street miles...
Mike
Old Jul 19, 2008 | 07:08 AM
boss351's Avatar
Cheers
Flushed using it and it is very easy to use (good pressure test on the system also). Go here for them plus you will see good prices for Motul and Pagid pads. Sorry, not sure if any of the 6speed sponsors carry the Motiv bleeder YET.
Old Jul 19, 2008 | 08:59 AM
vividracing's Avatar
no brakelines mike?
Old Jul 19, 2008 | 09:04 AM
landjet's Avatar
Better brake pad pricing here--www.ProBraking.com
Old Jul 19, 2008 | 09:54 AM
Mikelly's Avatar
I spoke with two race shops who specialize in Porsches and both said they didn't bother replacing the OEM lines. That's all I needed to hear... I'd actually bought new braded lines for my kit and didn't bother installing them... Sold them with the calipers/pads that I shipped to Sweden to one of the members here...
Mike
Old Jul 19, 2008 | 10:58 AM
I bet if you put some on you will have a much better pedal feel. You want to play the FREE Lines game
Old Jul 19, 2008 | 11:09 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Fronts
6 Pot GT3 Caliper
Brembo Floating 355mm Rotor
Pagid RS29's
Goodridge Braided Lines
Motul RBF600
GT3 Cup Ducts
Ducting from Techart Spoiler straight onto rear of front rotor
Rears
997 GT3 Caliper
997 TT 350mm Rotor
Pagid RS29's
Old Jul 19, 2008 | 04:35 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
for anyone that cares about squeal..the pagid oranges, that i had professionaly installed, squealed hardcore..with no exceptions.. aside for that, they stopped great.
Old Jul 19, 2008 | 06:06 PM
MGS996TT's Avatar
Thanks..
Old Jul 19, 2008 | 08:09 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Totally agree! Between handling and power, I pick handling any days.
Old Jul 19, 2008 | 09:16 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
EBC reds here (carbon, new formula). No issues on 35F days, no issues on track. No issues.... Now tires are another story.
Guys, the new ebc's are not bad. Try some....red is less dust, more "nice" per their site on rotors, but more street. Yellow is more DE/track....more dust.
JB
Old Jul 19, 2008 | 09:38 PM
tom kerr's Avatar
Steven and Mike have it spot on for track guys and they are some of the best on this board.
only thing I have done differently is slotted rotors up front and I like the pagid blacks in the rear to compensate for some front to rear brake bias.
As for the SS lines I think they could play a role in protecting the lines from getting cut on the track or wherever but as for increasing braking or pedal feel, sorry it just really is
urban legend.
