how many quarts of oil?
Old Aug 17, 2008 | 11:33 AM
unvmy996's Avatar
how many quarts of oil is the car supposed to hold ? i also had the turbos off and alot of oil drained out of there also , then put the turbos back on and changed the oil ....i put 8 quarts and the indicator still shows down at the last bar ..
Old Aug 17, 2008 | 11:38 AM
TT Tommy's Avatar
TT Tommy is infamous around these parts
I believe my mechanic uses 9 but I could be wrong.
tw
Old Aug 17, 2008 | 11:51 AM
silvershark's Avatar
silvershark is infamous around these parts
My Porsche mechanic said to put in 8qts start and check. Fill to appropriate
mark. 9-10qts total for oil change.
Old Aug 17, 2008 | 12:25 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
9.2 qts. last time i changed the oil.
Old Aug 17, 2008 | 12:31 PM
unvmy996's Avatar
aproxx how many little bars equal one quart of oil?
Old Aug 17, 2008 | 01:04 PM
wross996TT's Avatar
Engine oil quantity Approx. 12.5
change quantity 8.5 l (~9 qts) with filter change 8.75 l
The oil change quantity (without oil filter change) is approx. 7.8 litres after a dripping time of 20 minutes add until all 7 bars lit.
I believe each bar = .25 l (~.26 qt)
If you drain the turbos....good idea to prime the oil filter before you start up (also remove the fuel pump fuse #3)
Old Aug 17, 2008 | 01:08 PM
unvmy996's Avatar
thansk wross , i never heard of priming the filter and remove the fuel pump fuse .. what the purpose of that?
Old Aug 17, 2008 | 01:45 PM
wross996TT's Avatar
As you know the most damage done to an oil lubricated system is when the system is starved from oil...(e.g., start-up). When you drain the oil from the system and the turbos....when you first start-up, guess what...no lubrication. So the priming of the oil filter is to get the oil into the system quicker. You pull the fuse to the fuel pump to force the oil into the system and turbos without the car starting.
Old Aug 17, 2008 | 05:00 PM
unvmy996's Avatar
hehe , thanks wross.
Old Aug 17, 2008 | 06:35 PM
robertp's Avatar
When I drained the oil in the turbo’s oil tanks only ¼ of a quart was present. I added ¼ of a quart into the oil filter reservoir. Also, make sure you buy the extra oil filter “O ring” because it only comes with one (the large one).
Old Aug 17, 2008 | 07:57 PM
TT Tommy's Avatar
I believe it's 3 ?
tw
Old Aug 18, 2008 | 02:23 AM
anthracite's Avatar
anthracite is just really niceanthracite is just really niceanthracite is just really niceanthracite is just really nice
Start with 8 and fill it up with the 9th. After the 9th, my indicator showed 3/4. It is about 3-4 bar/qt
Old Aug 18, 2008 | 05:09 PM
WOODTSTER's Avatar
Don't overfill
Old Aug 18, 2008 | 05:16 PM
turbo turbo's Avatar
turbo turbo is infamous around these parts
your right, don't overfill it will smoke like crazy. don't ask how i know.......
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 22, 2015 08:00 AM
ECS Tuning - BMW
Sep 22, 2015 07:49 AM
oo7
Sep 10, 2015 08:08 AM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
