misfire/hesitate between 3000-3500 rpm...
Old Aug 28, 2008 | 03:48 AM
Imolas54's Avatar
Imolas54 is infamous around these parts
i have an 01 turbo with about 9000 miles on it now, when i am cruising on the highway with my RPM floating around 3000 rpm or 3400 rpm with maybe 10-20% throttle the car would misfire/hesitate..
However it does not have any signs of this hesitation when i am on the throttle and just revving the gear out.
Any idea what this might be?
TIA
Old Aug 28, 2008 | 06:19 AM
Erock's Avatar
Erock is infamous around these parts
I have no idea but my 01' does the same thing. If you find anything out please let me know.
Old Aug 28, 2008 | 06:26 AM
996twin_sc's Avatar
996twin_sc is infamous around these parts
Are you modified or stock?
Old Aug 28, 2008 | 06:37 AM
pogoteurfou's Avatar
pogoteurfou is infamous around these parts
Should be MAF , try to clean it
Here is a link to the diy : https://www.6speedonline.com/forums/...5&pagenumber=1
Hope this helps
see ya all and have fun
Old Aug 28, 2008 | 07:27 AM
wirx's Avatar
wirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud of
I got misfire too, problem was loose spark plugs.
Old Aug 28, 2008 | 07:35 AM
wross996TT's Avatar
after re-reading your symptoms I agree with ard...variocam
Old Aug 28, 2008 | 10:33 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
could be maf, plugs, coilpacks...
Old Aug 28, 2008 | 10:50 AM
ard's Avatar
ard
Variocam?
Pretty sure there is something that switches over or engages around 3100 that causes the feeling of a stumble. No codes, right?
Previously I'd heard this attributed to the variocam- mine was doing it before new plugs, and after.
Edit: Never heard it here, rather over on Rennlist it was kind of a "over course it is the variocam' response...
Old Aug 28, 2008 | 11:52 AM
DNugget991GT3's Avatar
my car does the exact same thing
and i have new spark plugs and a new maf ..
Old Aug 28, 2008 | 06:16 PM
SEAN 996's Avatar
SEAN 996 is infamous around these partsSEAN 996 is infamous around these parts
When you have the misfire/hesitations do you get a CEL code? If so what were they?
Old Aug 28, 2008 | 07:05 PM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Change the plugs, Check and change coils packs if needed ,try the car..Still same
Change the MAF and be happy
Old Aug 28, 2008 | 07:19 PM
maxboost's Avatar
maxboost is infamous around these partsmaxboost is infamous around these parts
loose spark plugs? huh?
Old Aug 28, 2008 | 07:36 PM
Dr. T's Avatar
Dr. T is infamous around these parts
A slight "misfire" at around 3100rpm is the variocam and is completely normal.
Old Aug 28, 2008 | 07:43 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
yes, completely normal - it's the variocam...like ard and Dr. T have said.
Old Nov 1, 2008 | 09:16 AM
riley6's Avatar
riley6 is infamous around these parts
Is it normal to get misfire codes due to the variocam issue? Is this something that requires repair or something that you can just live with?
