What would a bad turbo do?
Old Jul 12, 2003 | 03:50 PM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
I've been told by a mechanic who hasn't looked at my car yet but has raced and worked on many car s that he is sure I don't have a leak causing my loss in boost. Got me to thinking, what would happen if one of my turbos was bad? Would that result in half the boost, which is my problem? Shouldn't some kind of light come on if that happened? TIA
Old Jul 12, 2003 | 04:57 PM
oak's Avatar
oak
A bad turbo is one of the most difficult parts to troubleshoot, out side of the ordinary things to go wrong with a turbo such as bearings, seals, etc.
All it takes is a micro amount of misalignment or a tweaked impellor to make a major drop in power from my experience. It will still run well enough, but will be down on power. I have had similar experiences with brand new turbos out of the box.
Did you ever confirm if you still have the Hybrid turbos? I remember we had a discussion about the mods on your car after you had purchased it.
Old Jul 12, 2003 | 05:28 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I previously had a bad turbo. It caused a reduction in boost. Upon swapping out the turbos, full boost returned.
Old Jul 12, 2003 | 06:58 PM
cjv's Avatar
cjv
Moderator
If you made mods and consistently ran in overboost, there is a possibility the impellers are damaged.
Old Jul 13, 2003 | 03:41 AM
Red Devil's Avatar
CJV, I wouldn't think 0.9-1.0 on rare occassion would fit your definition of consistantly running overboost, considering the set-up. I know similar type set-ups that run higher without problems.
Old Jul 13, 2003 | 05:26 AM
cjv's Avatar
cjv
Moderator
Re Devil,
Any turbo can be run in overboost. Even he stock K-16's. For instance the stock K-16's and K-24's I believe are designed for a maximum ten contineuous ten sec overboost.
Old Jul 13, 2003 | 02:01 PM
oak's Avatar
oak
I've had an experience where the turbos would boost fine on the gauge 1.0-1.2 and the HP would be fine and would pull to redline easily but the torque was not there. The turbos were in a cavitation mode. For the most part it would feel very fast due to the quick spool up but lagged torque through the mid and top end. The turbos were boosting fine as far as intake pressure, but they were not flowing enough volume of air needed to increase torque. The funny thing is most people that have this set up probably won't even notice this.
Old Jul 13, 2003 | 03:18 PM
cjv's Avatar
cjv
Moderator
That is the result of cavitating a turbo. Like trying to get too much power out of K16's or sometimes K24's.
Old Jul 13, 2003 | 03:23 PM
oak's Avatar
oak
yes, Cjv That is the downside to Hybrids. If you decide to go this route make sure that who ever is sourcing or machining these types of turbos has been flow tested before sending them out.
Old Jul 13, 2003 | 04:39 PM
cjv's Avatar
cjv
Moderator
Oak
I did flow the latest ones we are about to dyno this Wednesday. They have the potential of 800 hp.
Old Jul 13, 2003 | 04:42 PM
oak's Avatar
oak
Holy beegeezus 800hp! I'm not worthy!
Old Jul 14, 2003 | 05:16 AM
Red Devil's Avatar
CJV, what is the definition of overboost then?
Old Jul 14, 2003 | 07:13 AM
cjv's Avatar
cjv
Moderator
Take the GT2 with the K24's. I am going by memory, but I believe they are designed for 155,000 or 165,000 rpm's. That is the maxium rpm the impeller is designed to turn. They are also designed to go into over boost which would be to spin or produce another 10,000 rpm's. However, they are not designed to run at this rpm for more than ten contineuous seconds.
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
alevine
Nov 4, 2015 10:05 AM
oddjob142
Aug 24, 2015 05:49 PM
magoochi
Aug 23, 2015 05:54 PM
