Brake fluid replacement
Old Oct 1, 2008 | 06:01 PM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
Originally Posted by BigBadBen
Talked to Rob K about this. Based on his recomendations I am going to change mine today with ATE Super Blue, that way I know my system is completely flushed and next year I will do it with Motul RBF600 which is a gold colour, each time you will know the fluid has been completely flushed cos of the colour change...anyway that is what I am doing and I don't track my car.
I would try getting the ATE Type200 it's the same fluid except it doesn't stain EVERYTHING blue like the Super Blue does.
Old Oct 1, 2008 | 06:46 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
As info, ATE manufactures Blue and Gold fluids.
Old Oct 1, 2008 | 06:52 PM
Mikelly's Avatar
Here's the "truth" about brake fluid...
You should replace the fluid every other year. Actually it is listed in your 15K service to be flushed annually, but every other year allows for what most manufacturers of the fluid consider "normal" use. Remember, it's hygroscopic and soaks up moisture like a sponge... For those of you not tracking, that's a bad thing.
Check the fluid manufacturer and porsche's recommendations for change intervals.
I'll NEVER go back to ATE fluid. It was not up to spec in my car in street driving, and for about the same money, Motul or GS610 is a heck of a lot better.
ATE Superblue wet 392 and dry 536 points vs. Motul wet 420 and dry 593 boiling points... Motul can be bought thru most vendors or motorcycle shops and will last under the hardest conditions, or daily driving.
Mike
Old Oct 2, 2008 | 08:59 AM
wachuko's Avatar
wachuko is infamous around these parts
Every 2 years.
or after every track event.
using Castrol SRF here...
Get a Motive bleeder and you will be able to do this very quickly...
Old Oct 2, 2008 | 12:09 PM
tom kerr's Avatar
agree above is good enough for a street car. the brakes see no were near the stress and heat on the street than at the track. dont over think this for a street car.
Old Oct 2, 2008 | 12:54 PM
MariusL's Avatar
MariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the roughMariusL is a jewel in the rough
I'm running Castrol SRF, change every year. Bleeding after (almost) each trackday. I'm doing 8-10 trackdays a year, and had no problem so far!
audipwr1
Sep 25, 2021 01:31 PM
rnl
Aug 26, 2015 02:36 PM
The Oss
Aug 24, 2015 08:19 PM
Ginuwine209
Aug 24, 2015 05:01 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
