broken trans mount
broken trans mount
I have two broken the rubber trans mounts and was wondering if anyone has a recommended upgrade? The shop I use has offered to make solid mounts out of Derilin for me. I'm just not sure if this will then require me to switch the motor mounts as well?
Also what have people been paying to get them replaced?
The current 997 product is an improvement over the ones that we had in our cars.
It is used in the 997 turbo and 997GT3. I bought it directly from my P dealer
(or Suncoast).
Marty K.
(or Suncoast).
Marty K.
Thanks Marty! Are they rubber? Do you think they are an improvement?
I look forward to seeing you Mike.
I've seen it from putting cars up in the air!
When your bushings in the motor and tranny mounts get worn, you'll eventually notice that your exhaust tips get pushed around by the body panel and will be pointing down, or you'll see marks on the metal trim ring on the rear bumper exhaust cutouts.
Mike
Mike
[quote=STEVE KOJASEVIC;2100160]how do u know when you tranny mount is broken ?
When I was doing an oil change I poped the underbody panel off just to look for loose stuff. What I found was one trans mount bolt almost all the way out. When I went to tighten it up I saw that the rubber was torn. The other side had the bolt all the way in but the rubber mount was also torn.
Unless you take off the underbody panel and look you will never know.
You going with the WEVO blue or WEVO Blacks? I'm thinking I'm going to go with the Blue, but I'd like to get some feedback from those who've done both... The blacks are stiffer than factory but not as solid as the Blues.
Mike
Mike
