clutch suggestions
Old Oct 29, 2008 | 08:53 AM
kirk911tt's Avatar
kirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud ofkirk911tt has much to be proud of
clutch suggestions
My newly chipped 996tt has developed a clutch slip from 3000-4000 rpm with wot. It has 55k miles and the PO never tracked it or raced. So I guess its time for a new clutch. My plans are to keep it as a street car with only the stage 2,exhaust and diverters. So the car is going to stay below 600hp. What I want is longevity and the oem clutch only lasted 55k so I want to upgrade it, but don't think the multidisk expense is needed. any suggestions would be greatly appreciated.
Old Oct 29, 2008 | 12:57 PM
996TT-SANTORINI's Avatar
996TT-SANTORINI is infamous around these parts996TT-SANTORINI is infamous around these parts
hi....i want also ask something......
i will do the stage with k24/18g..
and i want to know which is the best
clutch for 650+ps.......
thanks..george
Old Oct 29, 2008 | 01:22 PM
rosesplus's Avatar
rosesplus is infamous around these parts
Have either of you guys tried the search function?
Old Oct 29, 2008 | 03:27 PM
vividracing's Avatar
I would recommend the Clutch Masters Stage 3 with full disk. The Clutch Masters kit has been talked about alot on this forum. It is capable of holding 700HP but drives like stock with better bite. They actually use a Sachs Pressure Plate and Sachs Clutch Disk which then they beef up with their own material and specs. The kits include the OEM Porsche throwout bearing. I have installed several here and sold many nationwide. Always very very good results. When I had my 996TT I ran the same clutch but I went with the race version which was a 6puck design. Same bite but getting out of 1st gear stalled alot.
So... $1500 shipped to your door, go with the Clutch Masters Stage 3 Full Disk Clutch Kit. If your flywheel is hotspotted and needs to be replaced, you can get a new OEM flywheel for about $1100 or you can go with the Single Mass Aasco lightweight flywheel which greatly improves turbo spool as the car revs faster. However that flywheel will have some chatter when idling.
Here are the links -
Clutch Kit - http://www.vividracing.com/catalog/c...5-p-49671.html
Flywheels - http://www.vividracing.com/catalog/t...=38&class_8=38
Actual product picture from our installation
Old Oct 29, 2008 | 09:32 PM
josh@iautohaus's Avatar
josh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the rough
Put this set up from Vivid on a cust car. Great results, very streetable.
Old Oct 29, 2008 | 11:35 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Sachs stage III with LFW, good for up to 700HP. Or tilton dual disc also very good.
Old Oct 30, 2008 | 07:06 AM
OCTurbo's Avatar
OCTurbo is infamous around these parts
since this gentleman is planning on stopping at ecu, dv's and exhaust (500hp), is there a cheaper option for an upgraded clutch. a lot of the clutches suggested are good for 700 hp, but that seems a bit of overkill for a 500 hp car.
Old Oct 30, 2008 | 10:11 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I agree with above Post. Vivid has a stage II clutch.....Search is your friend
http://www.vividracing.com/catalog/s...5-p-45743.html
DAN**** Did you get my message?
Old Oct 30, 2008 | 10:14 AM
The Clutch Masters Stage 3 is perfect for that. Its capacity will allow it to hold up to 700hp but drives like OEM. If the customer wants to send us his clutch, we can upgrade it to the Stage 3 for $1000.
Old Oct 30, 2008 | 11:58 AM
kirk911tt's Avatar
Thank you all for the feedback; the only reason I'm not upgrading further is I already track a highly modified 951 and unfortunately don't fit in the 996tt with a helmet for the de's so it will stay only mildly modified.
Old Oct 31, 2008 | 08:28 AM
x50plt's Avatar
x50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to behold
996tt
[quote=kirk911tt;2112073] unfortunately don't fit in the 996tt with a helmet
Me too, it's a problem at the strip.
Blue Chip
Sep 10, 2015 07:07 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ship it
Sep 7, 2015 10:49 AM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
