Just installed my speaker covers today
Old Aug 29, 2004 | 04:47 AM
mroden's Avatar
mroden is infamous around these parts
Well, I finally got around to installing the carbon fiber speaker covers I picked up from Michelle at Cargraphic today. Not the easiest project I have attempted, but I think they look great.
mroden's Avatar
Here is one more...
Old Aug 29, 2004 | 05:06 AM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Looks great! And I'm sure you shaved .0000001 ounces of weight by doing this too!
bond's Avatar
bond is infamous around these parts
mroden -
You have a Private Message
Bond
Old Aug 29, 2004 | 05:56 AM
luting_chen's Avatar
luting_chen is infamous around these parts
btw...
does anyone know if that bose emblem can be removed????
Old Aug 29, 2004 | 06:01 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Walk us through it please. And leave hints.
Old Aug 29, 2004 | 07:19 AM
mroden's Avatar
Talking
Funny, because after I installed them I took the car for a drive and it felt significantly faster...
Old Aug 29, 2004 | 07:20 AM
mroden's Avatar
Originally posted by luting_chen
btw...
The emblem has two wires that are just bent over that hold it on. I removed them from my old covers and put them on the new ones.
Old Aug 29, 2004 | 07:42 AM
mroden's Avatar
Alright, first of all I found detailed instructions on Renntech.org for removing the door panel. Without that, I would have made no headway. You have to be logged into their web site to view the page, but if you search for "door panel removal" you will find the it. It has good illistrations to help with the process.
As it describes, you can use a plastic spatula (this works well) to release the clipped connection out of the door handle on all sides. This is the dividing line on the door handle. As you push the plastic spatula into the crease, move it along the line. You will see and hear the clips releasing.
Once you have removed that section, you will need to remove three screws. Two are Torx Bolts size T-30 the third is a philips head screw. After removing the 3 screws, you can begin to pop the door panel loose. I just used a screw driver under the bottom edge and worked my way around. I only went up halfway on each side as this gave me enough room to work on the speaker grills.
The grills themselves are held in place with push on nuts. You will need to loosen them slightly by prying a screwdriver under the edge. Once you have done that, you can apply pressure to the front of the grill close to the nut you are trying to remove. This worked for me as it just popped the nuts off.
Just put the new grill in place and reverse everything above...... I was able to reuse all the original nuts and clips.
Old Aug 29, 2004 | 07:47 AM
Dabum's Avatar
Dabum is infamous around these parts
Looks fantastic
Old Aug 30, 2004 | 10:46 PM
Joe West's Avatar
Joe West is infamous around these parts
Unfortunately, he gained weight... the door speakers are carbon fiber OVER the normal plastic... adding weight.
But who cares... they look awesome!
00aston
Aug 24, 2015 09:29 AM
