996TT catastrophic engine failure...
Old Nov 6, 2008 | 10:25 AM
  #61
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Originally Posted by rdss
Rick you must be strong man,you are taking this very profesional.No all here in this forum can help,but all of us feel sorry.Some like me need to know what realy happens to avoid be in your situation.I hope you can solve this no in a very expensive way.
I believe everything happens for a reason or higher purpose. There was a time in my life when I would have gone postal over something like this. And no, I'm not a strong man... probably no different then you. And yes... even though it was VERY embarrassing getting on 6speed and admitting... I BLEW MY ENGINE... I knew the experience could probably help someone else even though there might be some ridicule or a guy like Markski who is RIGHT... but doesn't mind kicking a dog when he's down (still love though bro!)
Old Nov 6, 2008 | 10:34 AM
  #62
RickEager's Avatar
Originally Posted by Ted
Nevermind
I'll try your login name.
Ted.
Hey Ted... sorry! Try me now!
Old Nov 6, 2008 | 10:40 AM
  #63
unvmy996's Avatar
Rick im anxious to hear news on your motor. Hopefully you do not need a new one ... then i would suggest, pauter rods, arp headstuds, and gasket. nothing more and you will be good to go.
Old Nov 6, 2008 | 11:04 AM
  #64
RickEager's Avatar
P.S: Did I mention I'm an Actor, Writer & Director. Some say a Film and life have no reality link - I disagree... like screenwriting a film, directing one, or acting... just like life... it's all a process until you get it right! You can check me out at... www.imdb.com & search "Rick Eager" Thanks too everyone for your support!
Old Nov 6, 2008 | 12:50 PM
  #65
Don't get me wrong... I'm not kicking you when your down... my friend as easy as it may look it still requires knowledge and hands on experience... especially when a greddy is involved.
You could have prevented a $15K motor going south. If I was your tuner I would be on the phone with you step by step during the initial start up and break in period making sure everything is OK.... heck , Im not even making money on this and guys call me all the time for help... so when I hear this it really sucks...
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 6, 2008 | 12:53 PM
  #66
RickEager's Avatar
WHOA!!! I just replaced this valve part #996 207 012 74 prior to the start up. I read where these units as you said can fail so I ordered a new one. The original part had a casting # 996 207 112 2R w/green dot on it. I pulled the new part out of the box and it had the same casting numbers as the original even w/green dot on it. The part # on the box was 996 207 012 74 though. I replaced this valve anyway. There's only one way to install it so I don't think there was an issue there. Could a new part have failed???
Old Nov 6, 2008 | 01:04 PM
  #67
RickEager's Avatar
mark
Hey Mark, You and several more guys like you are a TRUE asset to this forum. The amount of knowledge here is staggering - thanks Bro!
Old Nov 6, 2008 | 04:53 PM
  #68
vividracing's Avatar
Rick - I just talked to Sean, if you need me to replace 1 of the hoses, just PM or call me. If we can do anything to help you here at Vivid Racing with your rebuild, let me know.
Old Nov 6, 2008 | 05:12 PM
  #69
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
mark
Yeh Mark is bada$$!!!
He is a true asset to this board especially when I was routing the wiring and hoses for my EBC. Cheers Mark!
You rock!
Old Nov 6, 2008 | 06:13 PM
  #70
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Plus 4
You rock!
Old Nov 7, 2008 | 10:05 AM
  #71
RickEager's Avatar
Thanks... but what type of gasket???
Old Nov 7, 2008 | 12:14 PM
  #72
viperbob's Avatar
viperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud of
There is 2 things that still bug me though. One is that oil leak AFTER the incident. Immediately after the motor died I coasted to the side of the road. A small (50 cent to the size of a soap can lid) of oil was laying on the ground. When I got the car home I checked this out and the leak appeared to have came from somewhere up top near the center and dripped down the right side of the block near the rear, but not much.
Many times and incident like this will cause the camshaft plugs to get blown out causing an oil leak. I would look for the main cause..... Assuming nothing came through the block, this may just be a result.
Old Nov 7, 2008 | 03:13 PM
  #73
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
You rock!
+1
I'm very sorry to hear about your engine. Please let us know what you find out.
Old Nov 7, 2008 | 10:08 PM
  #74
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
BAD news.......good luck with the results of the teardown.......
Old Nov 7, 2008 | 10:27 PM
  #75
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
Not Good!! i now understand your post in my in my v-flow ad.. good luck with the rebuild.. my guess is bent rod or broken rod cap that hit the oil pump(its real close to cylinder 6)
tim
