Just got my car back from a GT28 and more upgrade..
Old Feb 20, 2009 | 01:33 AM
  #46
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I only go to 1.1 bar on pump with my Proto K24/18g. IMHO, the downside to running that much boost outweighs the upside.
Old Feb 20, 2009 | 01:54 AM
  #47
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
What you guys dont understand is tuners have different styles of tuning. Some tune for for less timing and more boost and others like more aggresive timing and less boost. You can probably get away with 2.0 bar as long as your timing values are very low. I ran a max of 1.1 with my old Protomotive tune but with my new EPL tune I run 1.3 on pump.
Old Feb 20, 2009 | 06:27 AM
  #48
vbzatty's Avatar
vbzatty is infamous around these parts
Actually, they found an air leak that was limiting the boost being seen at the DV's. Once this was fixed, I am now seeing 1.1 boost steady. Feels a lot slower now, but at least I'm not on the verge of going KABOOM! The air leak also was the source of my DV's opening early. Runs great now... but I have a check engine light so I need to see what has the ECU upset. I also want to find someone near Indy to do a dyno tune.
Colby
Old Feb 20, 2009 | 06:56 AM
  #49
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by jags911tt
When I had my gt700 kit it would make 1.5bar on pump and race.
That is correct (well you should only see a spike of 1.4 bar ...the dash gauge could be off)the difference between the two files on the old gt700 was in the timing and not boost.The timing advance is just as likely if not more to cause detonation than an increase in boost.
Old Feb 20, 2009 | 07:23 AM
  #50
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Something that is often over looked when people say "dont run more then 1.1 on pump gas". Run what ever your tuner says is safe. In our case, 1.3 is fine on all of our k24/18g files with injectors unless we specify other wise.
Old Feb 20, 2009 | 07:24 AM
  #51
Tony@epl's Avatar
Hey Don,
Set up sometime to see Jason. He can set you up with what ever file you would like (pump, race, water injection, etc).
PorscheEnthusiast
Nov 13, 2015 02:23 PM
alevine
Nov 4, 2015 10:05 AM
MurderedTurbo
Aug 28, 2015 09:06 AM
gulf gt
Aug 27, 2015 10:27 AM
Aug 19, 2015 06:55 PM
