1/4 mile cold temp advice request.
Old Nov 16, 2008 | 08:49 AM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
Went to SA Raceway last night for Midnight Madness. It was the coldest temp 34 deg per my dash and I was extremely excited to see what my Proto650 would put out with the nice cold air and high boost with 108 fuel. First run I launched at 4k and had a good amount of wheel hop with psm off and tires lowered to 29 ft/34 rear. I ran a 11.8@125 and my best time so far has been 11.7@127. My second pass I lowered tires to 25 rear and kept front same as before. I think I launched harder at 4500-5000 rmp and the car bounced all over the place with a 12.0@123.5. Called it a night. I'm not used to this wheel hop stuff b/c I typically run in 70+ degrees. What gives here. Was I launching to high in the pwr band for the temp?
Home bound with tires back to 36/44 I enjoyed seeing psm go off several times with 3rd and 4rth gear pulls and saw the dash boost at 1.4 bar holding so no doubt the set up likes the cold air. I would appreciate feedback from all those who have more seat time in cold temps. Thanks!
Old Nov 16, 2008 | 09:07 AM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
What were your 60' times?
Old Nov 16, 2008 | 10:33 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Careful with your BAR @ 1.4. If you say you don't have a 700 kit then you probably don't have injectors. I really have no clue what I'm talking about but, 1.2 on race gas is more likely a safer boost level to run with a stock fuel system.
As far as the 1/4 mile, I've netted my fastest 60' times launching around 3KRPM or less. Short shift first gear at 6250 RPM and ride out all the other gears. The best bet for getting a good time is going to a day at the track when there aren't so many rednecks.
Good luck. I know you can make it into the 10's, just takes a few more pulls then 3
Old Nov 16, 2008 | 11:34 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Hollywood,
It sounds like you're launching with too many rpms. With that trap speed, and your power, you should see low 11's at least. Good luck.
Todd
Old Nov 16, 2008 | 02:25 PM
60ft on first pass 2.05 and second with the major wheel hop 2.18.
Old Nov 16, 2008 | 02:35 PM
********I typically see 1.25 on the greddy and 1.3 on dash on warmer days on race fuel. I questioned Akram and Todd at Proto about cold days and high boost and they told me my system is set up to dump any overboost in a cold situation to protect itself. I have a 5 bar fpr and denso plugs but I don't recall if they did my injectors.
*********Got ya, everytime I launch near 3k my car bogs at the line so I started to rev higher. My better times had 60ft in the high 1's like 1.9. Thanks for the feedback.
**********Wow, 10's would be great and I hope to get there some day. Your right, I much prefer test/tune nights but this was the first below 60 degrees night so I went for it but only got in 2 passes in 3 hours.
Old Nov 16, 2008 | 02:37 PM
Originally Posted by BlackHorseTurbo
Hollywood,
Todd
I pretty much expected the car has low 11's in it so that's the goal for now. All that hopping freaked me out, I'm just glad I did not break and axle. Thanks Todd.
Old Nov 16, 2008 | 08:35 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Track temperature is likely too cold. Your RPM is fine during most conditions, I would suggest riding out the clutch a bit more and letting it take some of the abuse, you will get less wheel hop and your axles will thank you.
We just got a nice cold front here in FL, it's about time !
Old Nov 16, 2008 | 09:34 PM
Onelove-Good word and confirmation about what I was told the ats carbonetics triple disc clutch "loves to be slipped". In retrospect, even though my head was saying slip, my foot was likely dumping. Practice Practice. Thanks.
Old Nov 16, 2008 | 09:44 PM
onelove's Avatar
What I usually do it practice on the street coming out of the hole light to light. Normally by the time I make the 3-4 lights on the way to the track I have a good feel for the car on much slicker roads. Translating it to the track can take a bit more practice but once you get the feel for it and loose the fear you'll notice your times go down quite a bit. It's definately much easier when you know you have a clutch that will hold anything you can throw at it. Invest in a Gbox and you can get a good idea of how well you are leaving while practicing your launching using the 0-60 function.
Old Nov 17, 2008 | 08:32 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
127mph trap is good for High 10's? I would think you would need a couple more MPH to get down to a 10. A low 11 sounds about right.
Since you already have the 18G you should do the fuel system and turn the car into a beast. Then youll def be good for high 10s
Old Nov 17, 2008 | 01:36 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Yea i found slipping the clutch worked the best on a cold track, I was leaving at 15-1700 and ridding it out to get 1.9 but it blows the tires away if you release to early, Pratice pratice, Like Wes said.
Old Nov 17, 2008 | 07:16 PM
Chris Green's Avatar
Chris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond repute
you need at least 132 mph for 10's, I think the car good for a 11.3-4 with it lauched right.
Chris Green
Old Nov 17, 2008 | 10:39 PM
John@SpeedTech's Avatar
From my results and experience, I think Chris is spot on - anything is possible, but in general, when I was running 126-127 peak trap with 16/24 hybrids my ET's were 11.5 to 11.7, so an 11.3 would have been a very good run. Now, with a trap of 130-131.75, I have ET'ed 11.01, 11.08, 11.1, 11.2. With a little more boost/power, it would make sense that ET and trap would slightly improve, which would yield a high 10 and 132+ trap...I have kept the boost under 1.3 bar (1.24-1.27) with race fuel on all 1/4 mile runs.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Nov 17, 2008 | 10:40 PM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
careful with the wheel hops... You will end up towing the car home if you dont let off quick.. As for the launch the vbox is a great idea. I had pretty good runs leaving in the 2's... Had ceramic clutch that was tempermental to say the least but the kit you have can do a 10~~ !! you need to pracitice. Dont over shoot the rpms..stay in your powerband! and shift quick..dont lose boost!
