Milestone...Or Is It Miles-Tone
Old Nov 19, 2008 | 07:26 PM
t2_996420's Avatar
t2_996420 is infamous around these partst2_996420 is infamous around these parts
To all,
I reached another miles-tone this past Monday - 2003 Stock 996TT X50...Here's to another 100k - still smiling with that.........well you know the grin....T2 knocks on wood, climbs back in car for more smiling.....Ciao!! T2
Old Nov 19, 2008 | 07:41 PM
jpflip's Avatar
Amazing....With the same engine ??? What fail on the car during this period....Thanks, J.P.
Old Nov 19, 2008 | 08:03 PM
WOODTSTER's Avatar
Good questions!
What is your usage pattern and climate that you are in?
It obviously is a daily driver. Clutch, transmission, rear main seal, etc.?
Old Nov 19, 2008 | 08:15 PM
MBailey's Avatar
Please tell me its a 700+hp stock bottom motor that has seen alot of track time!!
Old Nov 19, 2008 | 08:39 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Three words. O....M.....G!
Old Nov 19, 2008 | 09:05 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Good to see you enjoy your TT as much as you can! congrats!!
Old Nov 20, 2008 | 05:05 AM
t2_996420's Avatar
Hey all,
It's daily driven in New england weather - sun, rain, slush, snow, sleet, etc - it's seen it all. Even 14" of the light fluffy stuff one night.
As far as maintenance breaking items etc....It's the original engine, orginal tranny, original turbo's, original clutch - yes it's the same one with that many miles on it (although we did replace two bearings) the clutch plate, pressure plate and flywheel or all in there with 200k miles. The rear main seal was not leaking at 173,000 but we replaced it when we did the clutch bearings. Oh the car is bone stock - no performance improvements. Shocks are so shot at this point it needs to go in to the shop - I am pretty certain it'll be KW-V3's. Here is the list of repairs I have done:
· All three front radiators
· water pump
· coolant expansion tank (as a precaution with water pump)
· power steering pump/reservoir (for the annoying squeal)
· right front bearing, left rear bearing
· front diff (due to front bearing issue)
· clutch accumulator and slave cylinder (4 times now for the slave - one time lasted only 4 days and it failed - PCNA pulled all the parts on the shelves in the US as a result of this and a few others in the country with a similar issue)
· wiring harness repair (passenger side front most cylinder – harness to the coil pack chaffing issue)
· rear main seal (while engine was down for a wiring harness repair we pulled the tranny to inspect the bearings, clutch, pressure plate and flywheel)
· two bearings in the clutch assembly – one was bad, one was fine
· Decarbon the secondary air ports from the intakes to the exhaust
· Gas cap – the gasket finally went at 186,000+ miles
· Check valve and carbon canister on the vapor recovery system for the fuel tank
· normal services done on time
· brake pads (only on the 4th rear set and 5th front set - car has PCCB's and is tracked 6-10 days/year)
· oil changes every 5000 miles religiously
· tranny and diff fluids every 60,000 miles
· Baileys DV's
I think that's it. It keeps me smiliing all the time!! T2
Old Nov 20, 2008 | 06:12 AM
Dr_jitsu's Avatar
200k..PLUS 6-10 TRACK DAYS...AMAZING!
Old Nov 20, 2008 | 06:43 AM
966tt650's Avatar
Awaiting Email Confirmation
966tt650 is infamous around these parts
Congratulations on 200,000. With New England weather it's all the more incredible & fun (though the weather has been pretty mellow since the highly controversial global warming). You obviously drive your Turbo the way it's meant to, no sitting in the garage and just looking pretty. Keep it up, enjoy.
Old Nov 20, 2008 | 10:47 AM
ard's Avatar
ard
I just KNEW that gas cap gasket was a weak link!
Congrats- Nice work.
A
Old Nov 20, 2008 | 01:49 PM
Ray's Avatar
Ray
For 2003 TT, you should have gen 1 PCCB. Are you saying still org. rotors with 200000 miles plus 30-50 track days? That's a real life test on how long can the PCCB last!!
Old Nov 20, 2008 | 02:53 PM
speedwerks's Avatar
speedwerks is infamous around these partsspeedwerks is infamous around these parts
Concur. You are 40K miles (25%) past what the factory says the rotors are good for. Can you post some photos of the rotor faces, and some thickness measurements?
Old Nov 20, 2008 | 03:02 PM
alzilla300's Avatar
alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !alzilla300 Is a GOD !
Wow, I'm amazed that you drive your TT so much! Congrats on making it 200K! Any chance you'll take it up to 300K?
Old Nov 20, 2008 | 03:30 PM
t2_996420's Avatar
To all,
The rotors are the originals (Gen 1) and the fronts are a little bit "scruffy" but not too bad and the rears are still in really good shape - no loss in thickness that I can tell. I'll try and get some photos over the weekend and post them. Thickness might be a tough one as I do not own a caliper to measure them. I have found that the best way to trea thte rotors well is a good three lap progressive heat up (as with the tires) and a good 5-10 minute cool down per track session.
I plan on driving it for the foreseeable future so another 100k may just be.................two short years way. Thanks T2
Old Nov 20, 2008 | 04:14 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Congrats - Truly amazing!
