anyone running 245/35/19 on the fronts?
Old Nov 30, 2008 | 05:36 PM
GT650-25's Avatar
GT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant future
I got some toyos sittin in my garage in 245's on the fronts...Any problems running these...
I am runnin a 315/25/19 rear...and have adj coilovers...
Let me know your thoughts guys...
Old Nov 30, 2008 | 06:09 PM
DNugget991GT3's Avatar
actually
thats the tire size i will be running on the front of mine
however, im RWD..
i think if u do a 315 25 and 245 35 , you might upset the diffs
Old Nov 30, 2008 | 06:15 PM
GT650-25's Avatar
no I checked with my porsche mechanic, whos actually good at what he does...he said rubbing issues will be it...do you know how much it will rub?
Old Nov 30, 2008 | 08:33 PM
Speedy996tt's Avatar
Speedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud of
If you are awd do not do it as it can cause your front differential to fail. You should only run a 235/35/19 if you are awd.
Old Nov 30, 2008 | 10:12 PM
GT650-25's Avatar
have there been any failures due to this?
Old Nov 30, 2008 | 10:38 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
I've read postings on front diff failures, but I believe the diameter difference was larger than what you're looking at (25.8 F, 25.2R).
Old Dec 1, 2008 | 05:24 AM
GT650-25's Avatar
Thats exactly what I meant, danyol...I cant see diff failure for .06mm difference. I could understand if it was like 1" or more or even mismatched tires and sidewalls...
But does anyone know how much rubbin? and if there are proven facts around diff breaking with this setup
Old Dec 1, 2008 | 08:11 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
i had that size as a front tire.. no rubbing issues... it worked fine on my car... just need to match them up with a close rear tire size
Old Dec 1, 2008 | 10:19 AM
Danyol's Avatar
I think the issue is more to do with PSM activation, Boca doesn't have an issue that's a good sign.
Boca, no premature activation of the PSM on bumps or fast exit ramps (I sometimes see it on the I-95 Copans exit from the S.bound side)?
Old Dec 1, 2008 | 11:09 AM
GT650-25's Avatar
I called damon at tire rack that said, it would have NO impact Whatsoever on diff but might cause rubbin so play with supsension to adjust height
Old Dec 1, 2008 | 12:21 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
My TT is max lowered with PSS9s & Cargraphic 19's and I have 245/35/19's fronts, no rubbing issues but it is very very tight but looks fab as well as a consequence
Old Dec 1, 2008 | 12:33 PM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
I have that size on the front with 295-30-19 in the rear and I get minimal rubbing in the front, and ONLY when I have the wheel at full lock. I just make sure i don't go full lock and I don't rub. The car is lowered pretty low as well. The rears are another matter though...
Old Dec 1, 2008 | 01:13 PM
Danyol's Avatar
Talking
25 series in the rear will cure that - I had the same issue
Old Dec 1, 2008 | 03:41 PM
GT650
why dont you go with a 255/30/19
on my 19" i-forged, the 235 BARELY rubs ducting for the radiators...
depending on how aggressive your drop, and what kind of wheels (offset) you have, it might rub
i had a 245 michelin ps2 on my car, and it did rub, but i dont care because im gonna have the suspension re-done so it doesnt rub ..
Old Dec 1, 2008 | 04:36 PM
boca996tt's Avatar
I didnt have any psm issues when I had the tires on my car.. and my car has lowered springs also
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
