Need advice please - Idle issues
Old Nov 30, 2008 | 10:30 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
I'm having weird idle issues at start up, and hesitation issues.
The car searches for idle to the point now that when its on its down swing thru 1000 rpm it dips too low and stalls. If I start the car and let it idle the problems are less pronounced. Because of my straight pipes I am usually trying to get moving as soon as possible, and this starts the problem. Lately after the car dies from the "idle hunting," it doesn't start right away. It takes a few extra turns of the starter to get the car going. I'm also having hesitations below 4000RPM.
Could this be plugs, MAF, or O2 sensor? Powell and I are going to meet up tomorrow at lunch and run his Durametrics software on the car. Any idea what we should be looking for within the program? I'm unfamiliar and trying to get a head start so as not to waste to much of Chris' time.
Thanks for any and all advice.
Ryan
Old Dec 1, 2008 | 06:04 AM
Dr_jitsu's Avatar
You have the stock air box, right Ryan? My car has the EVO air intake/Proto/Hitachi Maf combo w/ hunts at idle.
Change your spark plugs and at least she won't die at idle.
Old Dec 1, 2008 | 06:39 AM
ttboost's Avatar
there was a previous thread the last few days about a 30min MAF clean that seemed to fix issues like that?
Old Dec 1, 2008 | 07:26 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
i had a very similar idle hunting problem then stall with my car. mine would do this after i clear the CEL and with an boost/vaccum leak (clamp was loose)
Old Dec 1, 2008 | 08:06 AM
TXGold's Avatar
I just recently completed the MAF cleaning, for the third time in 6 months. It's almost like it's worst afterwards, this time.
Sean, I do have the stock airbox, and a K&N airfilter that is about 3 months old. I washed the filter out with water and then lightly sprayed it with K&N filter oil. I don't think it is the filter, as there isn't much oil on it at all.
Old Dec 1, 2008 | 09:10 AM
LWFW causes stalls too....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 1, 2008 | 09:32 AM
TXGold's Avatar
Any pointers on how to configure the Durametric software, and look for 02 MAF and/or plug issues?
Old Dec 1, 2008 | 10:17 AM
wross996TT's Avatar
Configure durametric?...Huh....just plug it into the OBD and select the Motronic 7.8 turbo....it will report the codes...You can also navigate through the modules for more info. (RTFM). There are several reasonable guesses above:
1. Plugs/coil packs...when did you last change /inspect?
2. Leak...somewhere in the vacuum system
3. Maf... personally I don't buy the clean the MAF thing (I've done it with zero results)...if the MAF is bad...it is bad...no resurrecting by cleaning.
4. LWFW, but I assume your programming has been modified to take care of this (mine was)
GL.
Old Dec 1, 2008 | 12:23 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I met with Ryan for lunch and to hook up the Durametric. There were no codes and everything (both bank o2s, timing, maf count, etc) were all normal. Nothing was lagging behind like they do when something is failing. The only thing we think it can be since it does it when it's on a cold startup is that it's a mixture of the straight pipes (with cats) and the LWFW. Since I put my straight pipes (no cats) on the car kinda shakes like its missing a tiny bit when it starts up, but after a second it stops. So that is my only guess what it could be. Everything else checked out fine.
Old Dec 1, 2008 | 12:31 PM
TXGold's Avatar
Thanks again Powell. I appreciate it. Hope you don't kill your employee's with the Garlic thing I got going on right now
Statman, did you have Kevin adjust for it? I need to call and see if there is such a fix for a K16 flash.
Old Dec 1, 2008 | 04:28 PM
wross996TT's Avatar
Yes, kevin programmed it for fuel, hardware (FPR, Hybrids, LWFW, intake..)and altitude
Old Dec 1, 2008 | 05:56 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
Ryan
Pm me when u get a chance.. There is a couple of things u can check.. I also have an xtra maf u can borrow
Tim
Old Dec 1, 2008 | 08:31 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
The best guy in Texas is Akram when it comes to Porsche.
Old Dec 1, 2008 | 09:13 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
One simple step to see if it is MAF related. Disconnect the MAF and turn on the car. I have raced with my car on my old stage IV set up with a disconnected MAF, nothing happened. How many miles on spark plugs? Were your injectors changed?
Old Dec 1, 2008 | 10:11 PM
TXGold's Avatar
I'm pretty sure we concluded that it's not the MAF. The MAF numbers matched up the same as Powell's MAF numbers. Isn't this an indication that its not the MAF? It has been 20K since the plugs were changed. I haven't touched the injectors.
