not seeing enough boost... .6 Bar max :(
yes, stock WGs.
When I had this issue, battery reset did not fix the problem. It was bad DV.
They are a PITA to get to, so you might try this: Disconnect the vacuum hose going into the top of the DV and attach a suction device, e.g., I used a brake bleeder gadget. One of the DV's failed to hold vacuum = boost leak.
If you have aftermarket DV's, you can take them apart and grease the O-ring.
Cold weather could affect this due to the change in viscosity of the grease.
Jon
Jon
Are you not supposed to see more PSI with that set up? I sold my stage IV Giac file to MotorsportsR. He has a GT2 and sees 1.2bar now and is happy. I will actually see him tomorrow at the raceway. You need to boost up more baby, sooooooon.
Yeah yeah I know! I am constantly evaluating all the options on the market and the installers around here.
Do you ever run 100 octane gas? I wonder with that aboard and colder weather what the boost will show?
No I have not yet. I have been told that with my Stage 2 GIAC tune the 100 octane wont help any. ?
If I were you I would give it a shot. Better octane rating will help any car IMO. Just wondering how clean the dyno will be.
why don't you email me your last dyno and I will take a look at it, if it is ok. What was your AFR? What boost? Temp? Octane rating?
art4iza@yahoo.com
art4iza@yahoo.com
art4iza@yahoo.com
art4iza@yahoo.com
thanks
