turbo check valves
Old Dec 4, 2008 | 06:07 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
turbo check valves
has anyone changed their check valves on the top of your turbos ?porsche sez they never change then on a service am told different
Old Dec 4, 2008 | 06:47 PM
if they go bad then you change them.... otherwise I dont think they touch them...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 4, 2008 | 06:59 PM
ard's Avatar
ard
am told different
What kind of "service"??? 'Swapping out turbo' service or 'oil change' service?
I recall YES on the first...
A
Old Dec 4, 2008 | 07:06 PM
turbos
i kinda thought if i had my turbos rebuilt they would include check valves. my local porsche dealer said they had zero in stock and had not sold a check valve in 4 years i gather they insure unrestrucked flow to the turbos am i correct?
Old Dec 4, 2008 | 07:11 PM
I have never seen rebuilt turbos come with check valves...
they are not cheap either... but whay are u even trying to replace them? I have a feeling ur tuner/ turbo rebuilder advised?
9.66
click to view
Old Dec 4, 2008 | 07:20 PM
turbos
had a failure and the check valves were brought into question. they are one or two hundred each am doing a flow test to c if i need to replace them
Old Dec 4, 2008 | 07:23 PM
the word was never replace a turbo without replacing the check valve. which i did not do when i added the newest turbos the lasted maybe 8000 miles
Old Dec 4, 2008 | 10:21 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
Agreed, my latest set of turbos came with new check valves. If something grenades, less risk of contaminating the new turbos. Also, change your oil, pull the fuel fuse and turn the engine over until fresh oil comes out the lines that connect to the check valves.
Old Dec 4, 2008 | 10:36 PM
ard's Avatar
ard
From Kevin at turboflatsix:
http://www.turboflatsix.com/destroy-new-set-t194.html
"These check valves were originally installed on a '02 996TT. The owner purchased a new set of K24's. Instead of ordering new check valves, the old ones were installed. One can notice that the valves is/are a two piece design. A stainless steel screen is used to filter out debris from entering the turbochargers bearing system.
When one makes the decision to re-use the check valves, you risk disrupting the filter screen layers. The debris migrates into the turbochargers. Bearing failure is 100%
Why does someone spend $2,500 to $3K on a set of K24's and then mounts the old valves."
My guess is that Kevin has worked on perhaps 50 TIMES as many turbochargers than niello's mechanic
Old Dec 4, 2008 | 11:43 PM
al@cpt's Avatar
al@cpt is infamous around these parts
Changing check valves = cheap insurance!
Old Dec 22, 2008 | 08:33 AM
Dr_jitsu's Avatar
I just installed the AFI turbo adapter kit and of course some new GT 3076's....I am trying to find out if the check valves were also replaced.
Anyone know if the check valves came w/ the kit?
vr6tee
Aug 29, 2015 03:52 AM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
socialpro
Aug 21, 2015 12:14 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
