Turbo Lag with New Exhaust
Old Sep 14, 2004 | 02:15 AM
dbturbo2's Avatar
dbturbo2 is infamous around these parts
I recently installed an aftermarket exhaust (to remain nameless) that had a few thousand miles on it from a friend (ECU is stock). I am now experiencing significant turbo lag in the low rpm ranges until about 4K rpm where the boost kicks in normally. If the O2 sensors were installed incorrectly would this trigger a check engine light? Any thoughts on possible causes/solutions?
Old Sep 14, 2004 | 02:35 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Did you buy the new exhaust with 1200 cell cats?
Craig
Old Sep 14, 2004 | 03:43 AM
dbturbo2's Avatar
no this is an exhaust that has been out for a couple of years with 100 cell cats.
Old Sep 14, 2004 | 05:16 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
I hope nothing was inside the exhaust to keep things from getting in it during transport. Hopefully nothing is still in there.
Old Sep 14, 2004 | 05:23 AM
ZAMIRZ's Avatar
ZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud of
What diameter is the piping?
Old Sep 14, 2004 | 10:56 AM
TCM's Avatar
TCM
TCM is infamous around these parts
Since the exhaust mates right up to the turbos, there are a variety of issues that could be occuring. As stated there could be some shipping material in the exhaust but that should have burned out. A more reasonable reason could be a cracked exhaust gasket/seal between the exhaust and turbo housing. I suggest you remove the exhaust and check things out again. Good luck and please let us know what the problem turns out to be.
Old Sep 14, 2004 | 11:46 AM
Zippy's Avatar
Sounds like it could be an exhaust leak pre turbo.
alevine
Nov 4, 2015 10:05 AM
km90265
Aug 31, 2015 11:00 AM
rgreenberg
Aug 23, 2015 07:06 AM
Lucid Moment
Aug 20, 2015 02:22 PM
oddjob142
Aug 19, 2015 12:27 PM
