For those that run spacers in the front - any vibration?
Old Jan 2, 2009 | 08:04 AM
M32's Avatar
M32
M32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond repute
Hey everyone,
I installed 10mm spacers in the front and although the car looks great, I get a pretty serious wheel vibration between 50 mph and 80 mph. Is anyone experiencing the same thing? I have a set of 7mm spacers that I'll try to put on but I'm afraid I'm going to have to go spacerless if I can't get this fixed.
Edwin
Old Jan 2, 2009 | 09:38 AM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
Edwin,
I had this same exact problem with a set of 7mm spacers I attempted to use on the front of my old n/a 996. My guess is that your 10mm spacers are not hubcentric, correct? If they are not, what is probably happening is that there is not enough hub sticking out with the spacers on the hub for the wheel to center itself on the hub (although it well be close to centered, if it is off by any minute amount at all, you will get a vicious wobble).
Here is what you can do to try to eliminate the wobble. With the wheel off the ground try to tighten the lug bolts as much as possible (get a helper to hold the wheel while you torque the bolts, if necessary). Torque each bolt a little at a time, and proceed in a star pattern, until the bolts are as tight as you can get them. Then, when you lower the wheel back onto the ground, hopefully you will have torqued the bolts enough so that the wheel won't shift on the hub when the weight of the car is on the wheel/tire. If you are unable to get the bolts super tight with the wheel completely off the ground, try lowering the wheel just enough so that it won't spin when you torque with a fair amount of force.
I've heard that some people have had luck eliminating vibrations by using this torquing method. I actually sold my spacers before I had a chance to try this. Let me know if it works, and good luck. Scott.
Old Jan 2, 2009 | 12:22 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Get the porsche OEM spacers 5mm for front and 17mm for rear...i had them in three P-cars and no vibration at all...They are not cheap,but they worth their money...
Old Oct 20, 2009 | 12:11 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Around how much? Thanks.
Old Oct 20, 2009 | 04:40 AM
Ray C.'s Avatar
Ray C. is infamous around these parts
I have HR 15mm in the rears and 7mm in fronts without any issues. The car feels solid at all speeds.
Old Oct 20, 2009 | 06:53 AM
jpflip's Avatar
Same thing here. H&R 15mm spacers on all wheels (the type that used longer bolts) and no vibration.
Old Oct 20, 2009 | 10:01 AM
landjet's Avatar
H&R spacers have their own hub centric lip that keeps the wheel in it's proper place.
Old Oct 20, 2009 | 10:44 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
I have H&R 7mm spacers in the front and they vibrate as well... not sure whats going on
Edwin
Old Oct 20, 2009 | 12:02 PM
bestint's Avatar
bestint is infamous around these parts
h&r / eibach hubcentric spacers never have that problem.
Old Oct 20, 2009 | 12:06 PM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
Edwin, are you using longer bolts since you have introduced the spacers?
Are the bolts appropriate for the wheel? Some wheels want the ball seats (like OEM), others want conical seat bolts. You might have an issue causing the imbalence/centralizing due to the bolts.
Adam
Old Oct 20, 2009 | 12:28 PM
smj996c's Avatar
smj996c is infamous around these parts
I have 5mm spacers and 7mm rearand no vibration problems - might be worth checking wheel balance and tyre pressures.
Old Oct 20, 2009 | 12:36 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
+1 on the H&R's, no problems at all here, had them on my M3 also and no problems
agree with smj996c on checking the balance
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
cab83_750
Aug 19, 2015 12:37 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
