JiC Cross settings
Old Jan 7, 2009 | 11:58 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
JiC Cross settings
I know many of you have the JIC Cross. I'm having mine installed tomorrow with AP control arms and GT3 front and rear sway bars. For primarily street driving what settings on the JIC Cross do you like?
Old Jan 8, 2009 | 06:48 AM
WOODTSTER's Avatar
For street I would go a couple clicks from full soft and you will have plenty of
stiffness and turn in.
remember that full soft is counterclockwise until it stops. The orientation is if you were looking at the ****.
MK
Old Jan 8, 2009 | 09:20 AM
EZ Cookin's Avatar
Thanks woodster, is this for both front and back? And how much drop is best on our cars?
Old Jan 8, 2009 | 09:52 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
I do 2 from full soft on the street. No issues.
JB
Old Jan 8, 2009 | 10:02 AM
vividracing's Avatar
The front is so light that it will have a "bounce" affect if to stiff on the street. Go with softer up front. For the rear, if you want more squat and bite for turns with acceleration, go soft. I usually put the rears at middle to start. But the front sway bar on the middle hole and but the rear on the 2nd from stiff.
Old Jan 8, 2009 | 11:07 AM
unvmy996's Avatar
since i use mine for daily driving when its the weather is good, i have the front full soft and the back 2 clicks to soft.. cuase even at full soft they are very stiff.
Old Jan 9, 2009 | 11:10 AM
Adjustments made? How is it handling?
Old Jan 9, 2009 | 06:49 PM
EZ Cookin's Avatar
I'll be picking it up Tuesday. Willlet you know how it rides.
Old Jan 12, 2009 | 04:01 PM
brain police's Avatar
brain police is infamous around these parts
Ez
I ended up with full soft front and rear, and I'm pretty happy with it. I didn't try 2 clicks from full soft rear...yet. I have the GT3 swaybars, adjustable drop links and adjustable rear control arms... all set to GT2 specs very similar to what Dan at Vivid suggests. My car is lowered approx 15cm from stock, though not too low, as I still drive it most days. I started with dampening settings at mid level front and rear and loved the ride on highways, though the front bounce on rough roads was a bit too much...and my wife and her DD's didn't like it either. I set them to 3 from full soft in front and 5 from full soft in the rear, and the ride was much worse, with still a lot of bouncing but none of the performance increase from the stiffer ride. A lot of creaking in the cabin as well, as if front and rear of the car were perpetually out of sync. At full soft, it's still a lot stiffer than stock, but doesn't punish you over potholes or other road hazards. I'll experiment with 1-2 clicks stiffer from full stock, and stop when my wife risks putting her eyes out. Good luck.
Old Jan 12, 2009 | 10:08 PM
EZ Cookin's Avatar
It sounds like you have tried a few settings with yours. I'll start at 2 from the softest and go from there. Good luck with your wife http://images.ibsrv.net/ibsrv/res/src:[media]www.6speedonline.com/get/forums/images/smilies/smLach2.gif[/media]
Old Jan 13, 2009 | 09:55 AM
doktordyper's Avatar
doktordyper is infamous around these parts
access to rear clickers
Excuse the ignorance here, but how do you access he rear clickers? I too, have JIC Cross from Dan....
Old Jan 13, 2009 | 12:33 PM
KrafTechnik's Avatar
KrafTechnik is infamous around these partsKrafTechnik is infamous around these parts
I believe on that specific model it's done from the top.
Old Jan 13, 2009 | 12:42 PM
Rears are on top of the dampers. reach behind the rear seats and pull up the carpet flat that is before the "bench" part. If you have the bose, you need to remove it.
Old Jan 13, 2009 | 04:00 PM
removing rear carpet
None of the carpet pieces want to come loose/off without massive force. Do not want to damage anything.... I do have Bose. Essentially 3 carpet sections: 1) directly behind seat back, 2) front part of bench (w/the Bose outlets) and behind running to the rear window. Which piece needs to go?
Thanks.....
Old Jan 13, 2009 | 04:09 PM
the carpet below the TURBO badge is what pulls up.
