Will be buying '02 tt next SAt if all goes well, 1 owner car, 24k mi, clean car fax,
Old Jan 24, 2009 | 08:13 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
supple lthr, nav, some carbon int, indepndent PPI was good. Is $51,000 reasonable? It is the black/black color i have been waiting for has tinted windows, ..? Spoke to sevice guy Over Revs " #'s were low", printout read; # of ignitions, range 1 = 1153, # of ignitios, range 2 = 5, outside rpm range (upper)1044.4h, outside rpm range (lower)1040.4h....what do these mean? I have 9 pgs of printout #'s any other suggestions would be appreciated. Have FVD flash, BMC, and div. valves here and ready to go in ASAP. Thanks , Scott
2001 modded M5, 2000 S4- 500hp track car, ML55 AMG, SC430, retct.hardtop, '05 modded SV1000s, '95 modded Vmax, '05 CRF 450R, 4wheeler... and soon to be 500hp 996tt !!!!!
Old Jan 24, 2009 | 08:47 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
Scott,
For your reference , i purchased an one owner clean 2003 car with similar options minus the nav with 26k miles for about the same price last december. So i say you can work the price down a bit ...but if this is the one ..just go for it. I spent way too much time to buy my car...that's the time i could be enjoying driving.
I would say if the PPI checks good , which looks like it is. The range 2 overev's of 5 seem like a low number to me. My car had 0 type 2,but that might be rare. The 1044.4h /1040.4h means when these overrev's occured, to me it seems like its very recent (last 4.4 hrs of driving). Type 2 are overev's which occur from downshifting or what many would call moneyshifting. Do a search on this topic "type 1 and type 2 over rev" its been discussed extensively. Based on your data , i would not be concerned if everything else checks out good.
This might not be a problem if you test drove the car enough and made sure nothing was wrong with the engine.
Good luck.
Old Jan 24, 2009 | 08:48 AM
vbmw335's Avatar
also did you check for 2nd gear pop out issues?
Old Jan 24, 2009 | 09:03 AM
drhenrock's Avatar
I will test drive it next week and check everything, Thanks!
Can 2nd gear po out be fixed and is it a real problem?
Old Jan 24, 2009 | 09:23 AM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
There is much written here on 2nd gear popout. It is a problem with some of these cars and very expensive to fix. Most of the cars do not have this issue but beware of the ones that do.
Old Jan 24, 2009 | 09:24 AM
vbmw335's Avatar
Anything can be fixed, but it is major dollars(last i heard 10k+). If it had the problem , i would totally walk away. There are way too many cars now in the market, just wait and find a good one.
Btw...do you know how to check for pop out? accelerate hard and deccelerate in 2nd gear a whole bunch of times and check to see if it still stays in 2nd gear.
I am sure others with more exp will chime in.
Old Jan 24, 2009 | 09:29 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
5 range 2 ignitions is very low indeed and nothing to worry about. An ignition is recorded each time a spark plug fires so that's not even 2 revolutions of over-rev.
Old Jan 24, 2009 | 10:37 AM
dreamtripper's Avatar
dreamtripper is infamous around these parts
Sounds like it's in good shape plus if it's got the options you're looking for, I think it's a fair price. If you want to spend $5K less, the quality of car would likely change - either more miles, not as good condition, not right color etc etc. Ofcourse, if you're patient you might be able to find the perfect car for a few $K less, but no telling how long that will take.
Old Jan 24, 2009 | 02:25 PM
josserman's Avatar
josserman is infamous around these parts
Out of curiosity what state is the car you are looking at located in?
Old Jan 24, 2009 | 03:35 PM
josserman's Avatar
Was this at Foreign-Traffic?
Old Jan 25, 2009 | 04:46 AM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
It is not $10k unless you take it to the stealership. There are several porche transmission specialists who can do this for under $5000 (possibly $3000) depending on what parts you need replaced.
Old Jan 25, 2009 | 08:43 AM
ttboost's Avatar
And if they know what they're doing they will use GT2 gears and synchros...fix it for good.
Old Jan 25, 2009 | 11:05 AM
BlueRanger's Avatar
BlueRanger is infamous around these parts
I think its a good price with clean PPI. I paid 56K last march for my 02 w/36K on the clock.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
gulf gt
Aug 27, 2015 10:27 AM
Nissan GTR
Aug 19, 2015 02:11 PM
roncooper
Aug 19, 2015 01:17 PM
