Best performance mods without turbo upgrade
Old Feb 1, 2009 | 01:33 AM
sharkster's Avatar
Originally Posted by FastPass
Hi ... New to the community and Ive got to say that there is a ton of info out there.... very impressed. As a newbie Porsche owner (2005 996 Turbo S Cab) I am unsure what upgrades to do and in what order. I felt that a flash, intake, dv's and exhaust would be a good start... am I missing anything? Not really wanting to tackle the turbos yet but I do want to make performance upgrade choices that I can continue to build on over time. Thanks in advance Thomas
You've got a good list right there for the power stuff (flash, dv's and exhaust) but don't forget the little things (not power related) like an SSK
Old Feb 1, 2009 | 03:29 AM
djtan's Avatar
djtan is infamous around these parts
Suspension first, then intake, software, and finally your exhaust. But hey! You already have one amazing car! Congrats!
Old Feb 1, 2009 | 11:13 AM
ard's Avatar
ard
Originally Posted by jalmood
Skip the intake, as in for example the FVD air intake plenum, thats what i'm about to install, should i replace it with a suspension?
On a stock car- K16 or K24- with just a flash and exhaust, an intake will not add much if anything at all.
Whereas a suspension will add performance at virtually ANY speed.
Old Feb 1, 2009 | 02:13 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
My short list for the most fun to drive
Exhaust
DV's
Flash
Suspension
Brake Pads
Drop some cheap weight out of the car.
That should leave you having fun, enjoying the car and getting the best bang for your buck.
Old Feb 1, 2009 | 06:44 PM
FastPass's Avatar
FastPass is infamous around these parts
Cool performance upgrades
Great advice on upgrades... Can't wait for spring. Thanks for all the help. Thomas
Old Feb 1, 2009 | 07:28 PM
Mikelly's Avatar
If it were me, and I've been known to be a bit of a NOOB, but I'd sped the money first on suspension, and then brakes.
A: Coil overs
B: Adjustable sway bars
C: Adjustable Drop links
For a street car you have more than enough adjustment for a street performance alignment. I'd shoot for 1.5 negative front camber and 2.0 Negative rear camber, with front Sway bar adjustments set soft and rear Sway bar adjustments set at firm. This will counter too much understeer.
If you plan to track the car on road course, you'll eventually need more negative camber and compensation for too much caster...
1: GT3 lower control arms front and rear
2: Pillow mounts (If they didn't come with the coilovers you bought)
3: Adjustable Toe Links on the rear
4: Motor and tranny mounts
I personally believe that the above are a total package recipee for the perfect street (and then ultimate track) 996 Turbo...
Then of course there is the Brake department... See the Sticky above!
Mike
Old Feb 1, 2009 | 08:34 PM
FastPass's Avatar
Thanks for the advice Mikelly...this is an S model with gen 2 pccbs. Still room for improvement? Any particular coil over you might suggest ? Bilsteins? Any particular Sway Bar? Thanks again for your insight. Thomas
Old Feb 1, 2009 | 08:55 PM
landjet's Avatar
After you've done the other mods, depending on what seats you have, you might want to upgrade to sport seats or GT3 buckets. The stock supple leather seats are crap.
Old Feb 1, 2009 | 09:00 PM
Mikelly's Avatar
For street use the PCCBs are fine. The PCCBs wear increadibly quickly on road courses, so you'd want to "downgrade" the rotor and pad to the more conventional steel rotor and aftermarket pads.
Lots of folks have had good success with the JICs, and their advantage is the billowball mounts. I personally have been using the PSS9s with great success, but they don't have the pillowmount/camber plates (and cost about $1000 less!).
Mike
vr6tee
Aug 29, 2015 03:52 AM
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
