Lou posting under Shank's Account: NEED YOUR OPINION ON SPRING DILEMMA:
Old Sep 23, 2004 | 08:04 AM
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
I had a local shop install H & R Springs on my turbo cab. The car dropped alot in height and the rear wheels have a very evident negative camber. I'm thinking 3degrees too.
How do I correct this?
Will it lower more when I put 19" wheels on?
Will the springs settle a lot more and continue to sag?
In addition, the car has a negative rake to it (the rear end is a hair lower than the front one)
-Lou
(pics here....)
Old Sep 23, 2004 | 08:16 AM
FAT-911's Avatar
FAT-911 is infamous around these parts
I had the same thing done, looks like the same height as mine as well, After the springs were installed I took my car back to Porsche for an alignment and was great after that.
Also with these springs do you get a knocking noise when you turn your steering whilst the car is stationary?
Old Sep 23, 2004 | 08:17 AM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Why only springs, Lou?
Old Sep 23, 2004 | 08:18 AM
AMG ETR's Avatar
Not sure if this helps you at all, but here is our 996TT Cab with H&R springs and 19's.... Not too much negative camber here...actually its factory spec.
Keep in mind it looks a bit wierd because the road is not level...its more even front to rear than the pictures look....
Evan
Old Sep 23, 2004 | 08:35 AM
20C4S's Avatar
cuz he won't keep it for more than a month, right Lou...
where is the TA spring?
Old Sep 23, 2004 | 09:01 AM
MCJ's Avatar
MCJ
MCJ is infamous around these partsMCJ is infamous around these parts
Might want to hold off on the alignment until the springs settle a bit.
Old Sep 24, 2004 | 02:32 AM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Evan,
IS the back that much lower than the front or is it just because in the pics the ground is not level? Thanks
Lou
Old Sep 24, 2004 | 02:33 AM
LSM's Avatar
LSM
Senior Member
I currently have the stock sport techno wheels on the car, I have HRE 542R's on order, will I then have to change the camber again? Thanks
Lou
audipwr1
Sep 25, 2021 01:31 PM
MadWhip
Sep 3, 2015 02:04 PM
gulf gt
Aug 27, 2015 10:27 AM
ECS Tuning - VW
Aug 26, 2015 12:33 PM
