Protomotive 24/18g idle speed
Old Feb 21, 2009 | 08:10 PM
luva966tt's Avatar
luva966tt is infamous around these partsluva966tt is infamous around these parts
Ever since I installed the 18g set up a month ago my idle seems higher than normal. It really didn't bother me until I got an low oil indication and found that I can't get a reading due to high revs (1000-1100 rpms) Has anybody else had this issue?
Old Feb 21, 2009 | 08:17 PM
ttboost's Avatar
Some tuners raise the idle to accomodate a LWFW? Maybe that's your issue? 1000-1100 is kinda high. Mine is about 850-900. Maybe you have a vaccum leak? Did it start idling high after your 18G flash?
Old Feb 21, 2009 | 10:14 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
+1
After turnover, my car idles at 900rpm.
Old Feb 22, 2009 | 06:46 AM
luva966tt's Avatar
I did have an lwfw installed while getting the 18g setup, and it did idle high after coming back from the tuners. will check for vacum leaks. Thanks
Old Feb 22, 2009 | 06:51 AM
ttboost's Avatar
If you have a lower idle (like stock) you will tend to stall it with the LWFW. Thats why tuners raise it a little. Maybe you could ask your tuner what your idle is SUPPOSED to be set at and see if it has changed, if not ask him to lower it and see if you like it?
Paintballzen
Oct 10, 2020 12:22 PM
AuZZie
Sep 2, 2015 04:26 PM
Suds26
Sep 2, 2015 01:33 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
