Going to 700HP! Need a little advice:)
Old Feb 23, 2009 | 05:36 PM
jsanch21's Avatar
jsanch21 is infamous around these parts
Based on the description below, what else would you recomend I purchase?
The base car: 2003 x-50 9K miles
  • Current mods: Protomotive ECU Tune, EVOMS gt-28, EVOMS Airbox, Hitachi MAF, Billet DV's, KW V-3, 6 piston 380 Brembos
  • Coming Go Fast Mods from Protomotive: 60lb injectors, Greddy Profec boost adjuster, Tial H20 Turbo cooling kit, Protomotive Intake Piping
  • I am looking to get the car to 700HP. I want this to be a reliable weekend driver. I have NO track or drag-race aspirations. I'll only do doing some freeway pulls and 2nd/3rd gear pulls around town here and there. I never launch hard in 1st gear.
  • Do I need beefier internals: Rods, etc...?
I will also purchase a lightweight clutch/flywheel and maybe upgrade the intercoolers at a later time.
Any tips from those of you that have taken a similar route is most appreciated
Thanks!!!
Old Feb 23, 2009 | 05:50 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Do you want 700 to the wheels? You should already be at 700 at the crank with those mods.
Thanks!!!
Old Feb 23, 2009 | 05:55 PM
jsanch21's Avatar
Sorry 700 crank HP I'm @ 600 ish now. The coming mods will be bolted on sometime next week! Also...what MAX boost are you guys running on 91 octane fuel? I'm @ 1.0-1.1 right now. Tks
Old Feb 23, 2009 | 06:00 PM
I'm sure it will rip.
Old Feb 23, 2009 | 06:18 PM
unvmy996's Avatar
i would deffinately upgrade the intercoolers when you do the rest of your mods .
as for boost on 91 i would asuume 1 br , but double check with todd ,
as for internals no you dont need them quite yet .
Old Feb 23, 2009 | 06:33 PM
jsanch21's Avatar
Thanks a bunch! Generally speaking, how is the daily driveablility on a 700hp car?
Old Feb 23, 2009 | 06:50 PM
Al Pettee's Avatar
Al Pettee is a jewel in the roughAl Pettee is a jewel in the roughAl Pettee is a jewel in the roughAl Pettee is a jewel in the rough
I have a 2005 TSCab with EVOMS' GT700 kit with EVOMSit, HMAF, EVOMS IC's, Sachs/EVOMS level 3 clutch, Milltek exhaust, and this is my summer DD car (at least to work). However, I come home from work in the PM, then hop into my 993TT, upgraded to 600++HP Protosport 3.8L, twin-plug, GT2871R's, for more excitement. I would say that the EVOMS 996 GT700 is the more refined-shall I say, boring-car compared to the tuned 993TT. Indeed, after I finish with stage 2 of my 993TT tune (down at Protosport now to get it over 700HP), later this year I plan to send them my 996 to move up to 800HP.
So the 996 with 700HP is almost docile and a great DD.
Old Feb 23, 2009 | 06:58 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Thanks!!!
I would say the clutch and intercoolers are must at that level.
... congrats, on having two great setups.
Old Feb 23, 2009 | 07:18 PM
RCNJ's Avatar
RCNJ is infamous around these parts
Thanks!!!
You also need an external and bigger internal fuel pump. You need between 1.3-1.4 bar to hit the 700 mark. That means race fuel no lower than 104 octane. At 1.0 bar you'll probably be around 600 bhp.
Old Feb 23, 2009 | 07:40 PM
yrralis1's Avatar
You must do the clutch and intercoolers . A stock clutch will not hold 700 HP very long. The transition to a stage three clutch takes some adjusting but I found that after 4K miles the thing which made all the difference was the GT2 conversion . It takes away the power assist and one can feel the engagement point much easier . The effort to press the pedal is greater but I don't mind one bit . I really disliked the stock clutch from day one . I preferrred my 997S clutch above it .
The intercoolers are another important option .
I found that the Tubi race exhaust has what i feel is the best sound I have heard on the car AND without cats the peformance gain is very noticeable. I almost wonder if my car is above 700 with the updated software and catless exhaust .
Daily drivability -- The car is quite civilized and whether its driven slow or fast is really up to the driver . But that would be the case with ANY car .
Lastly -- I suggest that you go over the full setup with your tuner. If you omit the clutch and intercoolers until later and wonder about street driving I feel that yoir specific system ought to have these questions answered .
Whether its on the track or the street --700 Hp is a lot and safety must be the top priority .
I recommend that you don't drive it anywhere until evey question you have is answered .
Good luck.
Old Feb 23, 2009 | 08:15 PM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
The car at 700 is very driveable ... U will love it!
Old Feb 23, 2009 | 08:39 PM
jsanch21's Avatar
Thanks for all the tips guys! Pls keep the advice coming:-) I will likely have all the work done @ Autotalent in West LA! Sam is a great guy, and I've seen the work they do! I have no doubt the project is going to turn out great!
Old Feb 23, 2009 | 08:42 PM
jsanch21's Avatar
For you SoCal power junkies, are any of you running 91 octane on a 700 kit? Thoughts, experiences? I could ask for a race fuel file as well if I needed it....
Old Feb 24, 2009 | 08:19 AM
donimac's Avatar
donimac is infamous around these parts
Smile
Suggestion: I say, order a second set of all the parts and then ship them to me so I can do the upgrade to my car. Let us know how you enjoy it at 700 HP.
Old Feb 24, 2009 | 02:54 PM
jsanch21's Avatar
Lol! Will do!
