upgraded headers...
Old Mar 11, 2009 | 10:35 AM
DNugget991GT3's Avatar
upgraded headers...
guys,
on a k24 car
what do upgraded headers actually do ?
for instance, the evo k16 headers on a k24 car ?
do they give you better spool up ? sound ? power ?
thanks
Old Mar 11, 2009 | 10:40 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Hi Steve,
You are going to get varying responses to this and if you search you will find some people say stock ported headers are fine up to 600hp while others will say headers do not make power. I say ask EVO, Switzer, GMG and AWE for the info and proof. I found a used set of headers (evo K24) in the classifieds for $500 and scooped them up. I personally feel they did help with turbo lag/response and am happy I got them for such a good deal. Would I pay the ~$1500+ for them new? Probably not....
Funny thing is I was at a tuners shop a few years ago and spoke about Exhaust manifolds and they said their testing showed no power improvements over stock (non-ported) Now a few years later they are offering them for the 996TT... The same shop designed a set to work with their 997TT systems and I believe the same header can be used for both cars. So I wonder what has changed? Things that make you go HMmmmmmmmmm?
Old Mar 11, 2009 | 10:48 AM
Alan
i know what you mean lol
im actually getting a free set
but i wanted to see if it was even worth putting them on the car at this point...
Old Mar 11, 2009 | 10:52 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
It all has to do with power level...Stock k16 car simply does not need headers...Stock k24 as well...But from k24/18g and over headers are starting to take place in order to gain hp and torque,especialy at low to mid rpm...When headers were installed to my car,i had to lower set gain to 75% from 80% to reach 1,4bar boost...This shows that the car could reach boost more easy...
Old Mar 11, 2009 | 10:54 AM
Originally Posted by STEVE KOJASEVIC
Alan
What specs is your car?
Old Mar 11, 2009 | 10:58 AM
K24 turbo
UMW flash (CRAZY torque down low)
lightweight flywheel
evo waste gates
diverter valves
RWD
K&N air filter
GT2 intercoolers...
1.2 bar on 93 pump
car makes 500rwhp
Old Mar 11, 2009 | 11:50 AM
jmenge's Avatar
jmenge is infamous around these parts
Hmmm, wonder how headers stack up to a ported exhaust manifold on cars with say a k24/18 setup?
Old Mar 11, 2009 | 12:03 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Steve, i really think it matters what headers.
I don't want to get into too much detail, but i've seen gains with my scargo headers...
Old Mar 11, 2009 | 12:24 PM
the headers are from EVO
i believe they have some sort of black ceramic coating for heat insulation ... ???
Old Mar 11, 2009 | 12:41 PM
If it came from evoms that way, its probably swain coating.
Do you know which ones it is: k16, k24, gt?
Old Mar 11, 2009 | 12:48 PM
theyre the k16 ones
Old Mar 11, 2009 | 12:54 PM
I think they are "worth" putting on, only a 10 min job to swap them...
Old Mar 11, 2009 | 12:58 PM
is it a DIY ?
do i have u buy any sort of gaskets ?
Old Mar 11, 2009 | 01:03 PM
str8blst's Avatar
theyre the k16 ones
I personally wouldn't put the EVO K16 headers on a K24 based car. I would call EVO and see what they say though....
Old Mar 11, 2009 | 01:20 PM
is it a DIY ?
you could replace the gaskets, although they are re-useable.
The k16 headers were desgined for k16 turbos, although the tubing diameter is still larger than stock...
The gasket numbers are:
996.111.215.70 -this is gasket from headers to turbo.
996.111.107.71 -this is gasket from head to headers
