The Official- How to use your Durametric
Old Mar 18, 2009 | 10:17 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Well, I'm new to Porsches and even newer to my Durametric tool.
So far I've learned how to pull the codes, reset the codes and adaptations.
I also figured out how to use the triggers.
I've also learned how to log "things".
I say "things", cause I got no clue what most of them actually do
I'm sure I'm not the only "dummy" here as to all these "things", and I'm sure some of you have figured out a way to track such things as A/F ratio since our cars have wideband 02 sensors, and monitor if your cars are running top notch. What I'm asking is, if we could get everyone who has any experiance with diagnostics using durametric to step forward and share their expertise Maybe even the durametric guys themselves
Old Mar 18, 2009 | 10:40 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
i just got mine and i keep getting "L line stuck to ground and K line stuck to ground" which keeps me from datalogging. Any suggestions anyone.
Old Mar 18, 2009 | 11:38 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I live in Belgium and when Tony from EPL wrote a flash for me I always had to take a drive and log with my durametric software and sended the results back to Tony so he could make some fine adjustments
I had to log RPM , engine load ,air fuel from the 2 banks and also injection time.
You have to select the data you want to log and press start when it has to start recording when this is done you have to select stop and export the data and it will be stored as a excel file, Not difficult at all.
Old Mar 19, 2009 | 12:58 AM
adam699's Avatar
Some of the data options are self explanatory but what were the two options for the a/f called?
Old Mar 19, 2009 | 06:06 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
It is my understanding from the Durametric rep that Lambda (A/F ratio) readings are not representative at high RPM. The ECU won't provide a high enough sampling rate per second to give meaningful data.
Old Mar 19, 2009 | 07:05 AM
dixie's Avatar
Here is an example of a log with durametric,lambda (A/F) seems to work for me at high RPM also but you need a good laptop,the conversion from lambda to air fuel I made myselve in exel..
Old Mar 19, 2009 | 07:11 AM
dixie's Avatar
Here you can see a better example,the first one didn't show to values I recorded..
Old Mar 19, 2009 | 08:37 AM
Al Norton's Avatar
That looks like a pretty good sampling rate per unit of time at high rpm (17 times in 0.6 sec.) I really don't know what rate is required to get accurate data. I posted info the Durametric guy gave me so I never actually tried to log any high-rpm data. Perhaps the build of his program has changed since I spoke with him last year.
Old Mar 19, 2009 | 12:11 PM
dixie's Avatar
The durametric software gets updates very often so I suppose it always gets better.You can download the newest software from durametric but you need the cable to make it work,also the less values you set for scanning the faster the program reacts,so if you would only scan rpm and a/f you would even get faster results than I did...
Old Mar 20, 2009 | 02:26 AM
adam699's Avatar
Can you show me how you converted the Lambda results into Air Fuel?
Old Mar 20, 2009 | 02:27 AM
adam699's Avatar
Also,
I was messing with the DUrametric today and found out that MAF Hot Film will give you the voltage of off pin #5 on thw maf, which can be useful when cleaning/diagnosing the MAF as per my DIY MAF article.
I also ordered Autoenginuity Tool today to compare the two, it seems more useful as it can be used on other cars, but we shall see
Old Mar 20, 2009 | 08:40 AM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
Dixie, would you be able to share your Excel sheet with everyone so we can have that calculation? Please
Old Mar 20, 2009 | 09:27 AM
j.mitchell70's Avatar
j.mitchell70 is infamous around these parts
Is the autenginuity tool as complete as the durametric tool? I'd love to not purchase things twice.
Old Mar 20, 2009 | 01:26 PM
dixie's Avatar
How to go from lambda value to A/F :
Just multiply the lambda value with 14.7 and you'll get A/F
So 0.8 lambda is : 0.8 * 14.7 = 11.76 A/F
If you want to change all values from lambda to a/f in excel you have to select an empty cell and select it, type: + and select the top lambda value,then type * 14.7 and enter,now you can pull down these cell and all lambda values will be set in A/F.
Difficult for me to explain in English but the simple way is to multiply the lambda value with 14.7 and you got a/f.
Old Mar 20, 2009 | 03:54 PM
adam699's Avatar
Ok, I got that
Now, if you could tell me step by step how to make a graph in excel? I keep on coming up with come goofy graphs.
