V Clamp Sizing & Application (CAT to Muffler Bypass)
Old Mar 22, 2009 | 05:49 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
I am now the proud owner of lightly used, (and I mean lightly, these things are like nu). FabSpeed 996TT Sport Imported Racing Catalytic Converters with Muffler Bypass Pipes, but sans V Clamps.
I purchased the pipes used from a 6Speed Sponsor,
Pipe ID at Flange: 2.4" (ish)
Pipe OD at Flange: 2.5"
Flange OD: 3" as near as dammit.
Do you think I can find, or decipher which V Clamp that is compatible? Well depending on where you look V Clamps are based on ID of incoming pipe. OK, 2.5" right? Wrong! a 2.5" clamp expects a 3.2" or there abouts Flange OD and as they have minimum openings, this will not work.
Can anyone help?
SWR
Old Mar 22, 2009 | 08:13 AM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Get the OEM muffler clamps off a regular NA 996. They will work and they are a LOT stronger. You should be able to find them fairly cheap. I believe FS sources the clamps from an outfit in the UK, it looks like Tubi even uses them on their race muffler.
Old Mar 22, 2009 | 07:12 PM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
I have the same setup and also made the mistake and bought the wrong ones that were sized bigger... I got the right ones from ATP Turbo for about $16each.
http://www.atpturbo.com/Merchant2/me...egory_Code=CLA
V-Band Clamp - 2.50"
Heavy duty stainless steel V-Band clamp for turbo discharge setups or to mate (2) of our 2.5" v-band flanges. This clamp is made from Stainless Steel. 2.50" refers to the tube diameter and this clamp is used for industry standard 2.5" v-band flanges that have an outer edge of about 3.1". 2.5" refers to the outer diameter of the tube used on this size vband flange.
Old Mar 22, 2009 | 10:13 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Out of curiocity, did you buy these as a setup?
Old Mar 23, 2009 | 05:50 AM
sid350
Brilliant, definately the dogs bollocks on this! Just ordered some from eBay.
http://cgi.ebay.com/ebaymotors/NEW-2...Q5fAccessories
No, Cats from Source A, Pipes from Source B. turned out to be a LOT more cost effective. about 1/4 of the price actually.
SWR
There are some nice 100 cell cats on ebay right now. I can vouch for the vendor. It is not me by the way, it is the place I bought mine from. They were just like NU.
Old Mar 23, 2009 | 07:28 AM
adam699's Avatar
Originally Posted by ShokWaveRider
sid350
No, Cats from Source A, Pipes (with wrong clamps) from Source B. turned out to be a LOT more cost effective. about 1/4 of the price actually.
SWR
What about the Pipes?
Let me know how loud the car will be when you put them on
Old Mar 23, 2009 | 07:34 AM
Pipes I also got used from a sponsor on this board.
SWR
Old Mar 23, 2009 | 08:12 PM
TT Surgeon's Avatar
Back when I ran fabspeed stuff the weak link was always the v bands, they are weak and flimsy. The bolt is a 1/4" grade 5 bolt rated at 12-15 ft lbs of tq. trust me, after you loosen and tighten them a few times they are done, they will loosen and start to induce drone. The best option is the much stronger oem porsche 996 c4s muffler clamp with a stout heat treated grade 8 case hardened steel german bolt, run about 25$ a pr.
The rest of the FS stuff is decent, but the clamps are junk. Been there, done that, got the t shirt.
Old Mar 24, 2009 | 03:48 AM
TT Surgeon:
I somewhat agree, and for $60 a pair certainly not worth it. does anyone have the part number of the OEM Porsche C4 Clamp? Even though I do have 2 sets of the Fabspeed Style on their way. I they fail, I will get the good ones.
SWR
Jun 10, 2017 07:45 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ct-andy
Cayenne 958
Aug 21, 2015 02:08 PM
ModBargains
Aug 20, 2015 12:28 PM
