Best Diverter Valves?
I am in the market for some - what are the best diverter valves?
Also, does the "F" hose need replaced, is it recommended, or just if it is bad?
Thanks in advance!
Thanks in advance!
I went with the Forge DVs too and am very happy win them
Personally I think the silicone hoses are a waste of time
I know I'm gonna get shot down here, but I think the stock hoses are more than adequate if they're in good order
If my hoses did ever need replacing I would probably go with the silicone ones, but I wouldn't change them unless there was a problem with the current ones
Just my thoughts though
Thanks Al! Vivid sells 2-3 different brands. Do you remember if they are Agency Power or Forge? No biggie, just curious what everyone is running.
Thanks again!
Thanks again!
I went with the OEM JDM EVO Blow Off Valve. It is a very solid unit that will last a long time. It is a much more solid, simpler, reliable, and cheaper than the the dual diverter valve setup IMO. Install is very easy as well. They are about $50 used and about $130 new.
http://www.extremepsi.com/store/cust...t=970&page=114
AP. Thanks for bringing up the name. I couldn't remember it but you jogged my memory. Quality of the product appeared to be very good.
The guys running Forge DV's what colour springs are you running ? Believe they come with green springs as standard but also yellow and blue springs with shims for running higher levels of boost.
