no headlights tonight!
Old Apr 17, 2009 | 07:54 PM
naptownmike's Avatar
naptownmike is infamous around these parts
I was out tonight and on my way home no lights only the running lights came on. Anyone else have this problem before? The last week or so the lights have had a small delay after turning on before they came on. Any thoughts on this would be great.
thanks mike
Old Apr 17, 2009 | 10:25 PM
Chris Green's Avatar
Chris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond repute
thanks mike
95% of the time it's the headlight switch we change them all the time. hope this helps.
Chris Green
Old Apr 18, 2009 | 06:25 AM
thanks Chris I will try that first.
mike
Old Apr 18, 2009 | 06:27 AM
heron163's Avatar
heron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond repute
sometimes the headlight(s) become loose and you need to tighten them up to ensure full contact for the plug ins
Old Apr 18, 2009 | 09:11 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
I'm having similar issues with the lights taking time to come on. I jiggled the switch but that doesn't seem to do anything. I did turn on the brights and that seemed to get the low beams on.....
FWIW
Sameer
Old Apr 18, 2009 | 09:51 AM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I had a problem with the ignition switch, wiggle the key and see if the lights (and ac fan) come on. Basically when you turn the ignition key, it doesn't rotate all way back by itself. You will need to replace the gun shaped piece the ignition barrel fits into, relatively inexpensive, but a pain to fix.
Old Apr 18, 2009 | 10:30 AM
thanks for the replys I will look at it again today.
thanks mike
Old Apr 18, 2009 | 03:59 PM
turned out to be the ignition switch I turned it back a bit and the lights came on. Thanks agian for all the replies.
mike
Old Jul 18, 2009 | 12:53 PM
SupercarInc's Avatar
SupercarInc is infamous around these parts
Just about to post a thread about this. Glad I used the search feature! Thanks you guys! I have a 2003 Twin Turbo Tip with the same problem and it was the headlight switch. Jiggled it and they popped on after a while.
Best,
John
DYL 911
Oct 20, 2025 05:08 PM
airbusdrvr
Dec 27, 2015 07:43 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
DYL 911
Oct 1, 2015 02:47 PM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
