Weird noise coming from the front....
Old Oct 13, 2004 | 08:15 AM
Jesus's Avatar
Jesus is infamous around these parts
I recently changed all the tires of my 996TT, however the car continues on vibrating and stuff, I replace the stock tires ( Pirelli) with the tires that the GT2 uses. The car is balance, aligned and everything...could perhaps something in the suspension be messed up??
Old Oct 13, 2004 | 08:20 AM
trojanman's Avatar
Welcome to the OC, bitch!
trojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant future
I would definintely check out the suspension. See if the dampers are leaking or if the springs are cracked/damaged.
Also check out the brake rotor - this could cause a vibration when braking.
Old Oct 13, 2004 | 08:26 AM
Jesus's Avatar
Thanks for your quick response, I will check on those factors because I have replace the tires already and never had this situation. Its annoying having that loud noise.
Old Oct 13, 2004 | 04:17 PM
ebaker's Avatar
ebaker is infamous around these parts
If it vibrates with new tires you probably have a out of round wheel.
Old Oct 13, 2004 | 08:32 PM
Cruzin's Avatar
Cruzin is infamous around these parts
The Hunter GSP 9700 might be the way to go for balancing machines.
Old Oct 13, 2004 | 10:39 PM
damon@tirerack's Avatar
Moderator
Try this link, it'll tell you where a shop in your area is:
http://128.242.141.111/pub/search/FindGSP9700.cfm
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Oct 15, 2004 | 04:21 AM
Jesus's Avatar
It ended up being a front wheel bearing....thanks guys !
tzeseong
Aug 17, 2024 11:08 AM
docboy
Sep 6, 2015 06:57 AM
New991S
Aug 31, 2015 05:22 PM
mlife2878
Aug 26, 2015 07:02 PM
Zero911
Aug 24, 2015 06:51 PM
