installed protomotive intercoolers pics inside
Old May 6, 2009 | 08:49 PM
  #31
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
i did a bunch of pulls today to check the cooling effect/heat soak of the new ic's im happy to say the the intake air temp only raised around 7.5 degrees under full load 1.4 bar this is amazing!!... the ambient air temp was 75 degrees
Old May 6, 2009 | 09:19 PM
  #32
WOODTSTER's Avatar
Nice,
I have the same large proto I/C's and they are terrific for repeated high boost or high temp runs. Like a 20 minute session at a road racing track or repeated quarter mile runs without shutting down or the TX Mile. Good Stuff.
Marek,
Yours like great too, cant wait to see what you have up your sleeve this summer.
MK
Old Jun 19, 2009 | 10:53 AM
  #33
RUF QTR's Avatar
RUF QTR is just really niceRUF QTR is just really niceRUF QTR is just really niceRUF QTR is just really nice
Colorinc , was the pills in 4th gear to redline ? what speeds did u go up to?
Old Jun 19, 2009 | 01:04 PM
  #34
Prche951's Avatar
Those proto IC's are huge and very nice. Markski, yours look even bigger. What about P drop across either of these units, does it increase lag a bit? at the obvious gain of wot power...
Old Jun 19, 2009 | 01:06 PM
  #35
colorinc's Avatar
they were 3rd gear pulls to redline.. the speed was close to 100mph
Old Jun 19, 2009 | 01:08 PM
  #36
the taller the IC the more the pressure dropps... but we make it up with the 2.5 inch all around hard piping.... my ics flow almost 200 cfm more then the current 3.5 inch ics out there... yet the 6 inch flow another 100 cfm....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 19, 2009 | 02:44 PM
  #37
RUF QTR's Avatar
It woud be interesting to se 4th gear runs since it will hav time for the intercoolers to soak....
Old Jun 19, 2009 | 02:57 PM
  #38
Prche951's Avatar
amazing how much room there is in that little area. When you first take it apart it looks like there is barely enough room for the factory IC's, then you see bigger IC's, and it dumbfounds you.
awdbiturbo1
Feb 18, 2016 10:24 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
