installed protomotive intercoolers pics inside
Subscribefirst off i would like to thank todd and the gang at protomotive for great service and an awesome well built product the fit and finish was perfect!!
the install of these massive protomotive built 4.5 inch intercoolers yesterday was pretty straight forward if you have ever done a turbo swap you can do this.... the only major things you have to do is remove top shroud add some air dams and modify the bottom shroud pull 2 new new vac lines for the relocated dv's... this is quite an upgrade coming from the gt2 ic's... the proto ic's are massive with huge free flowing end tanks the ic exit is now a full 2.5 inch which mates up perfectly with the proto y-pipe.... also replaced the plugs with one step colder denso pk22pr8 and topped them off with new 997tt coil packs took around 7 hours total not to bad.. took her out for a quick spin last night and it now breaks the tires loose on low boost(1.1 bar) did a couple of high boost (1.3 bar) 50-140 pulls and all i have to say is its a handfull
.. good fun.. enjoy the pics let me know if anyone has any questions
tim
all the pics located at the link below
http://picasaweb.google.com/carsandc...eat=directlink
.. good fun.. enjoy the pics let me know if anyone has any questionstim
Decent looking units. Pleasantly surprised to hear they made such a difference in performance. Was thinking of picking up a proto IC for my 993 but maybe will go for 80+ lb injectors and a new proto tune for more power w/ the 996. Headed to mid-michigan now for some tasty 112 fuel till someone around here decides to supply C16/import/Q16... Post new times if you get any!
How much were they may I ask? I just looked over their WEB site and to look at it you wouldn't think they sold much in the way of parts at all - nothing listed
Are those diverters blowing to atmo? Hard to tell from the pics on the site, if so any issues with fuel management or have you gone standalone\MAP sensed?
Edit: Looked closer, you've really streamlined the intake to the turbos! That's either MAP or a pressurized MAF, which is it? Will those filters flow enough? They look to be getting nice cool air that's for sure!
P.S. I second the call for times or other data. They certainly look like they ought to flow better and absorb more heat!
Are those diverters blowing to atmo? Hard to tell from the pics on the site, if so any issues with fuel management or have you gone standalone\MAP sensed?Edit: Looked closer, you've really streamlined the intake to the turbos! That's either MAP or a pressurized MAF, which is it? Will those filters flow enough? They look to be getting nice cool air that's for sure!
ahh the 112 thats good stuff... how is the 996 running? 80lb huh looking for a bit more power? ill get some times as soon as the temp gets a little warmer its hard to hook up
tim
tim
Quote:
the ic's run $3600 and some change.. as for protomotive's site most of there stuff is custom and most people dont do the install stuff in there garage
they either send it out to proto or have there indy do it... the dv blow off to atmos.. i am rumming a pressurized ford maf sensor.. the filters seem to flow enough they are 5.5 inches long 5.5 in dia..in the next couple of weeks ill be bringing the car down to protomotive for dyno tuning .. i will post some 6-130s and a few pulls
tim
they either send it out to proto or have there indy do it... the dv blow off to atmos.. i am rumming a pressurized ford maf sensor.. the filters seem to flow enough they are 5.5 inches long 5.5 in dia..in the next couple of weeks ill be bringing the car down to protomotive for dyno tuning .. i will post some 6-130s and a few pullstim
Are those diverters blowing to atmo? Hard to tell from the pics on the site, if so any issues with fuel management or have you gone standalone\MAP sensed? Edit: Looked closer, you've really streamlined the intake to the turbos! That's either MAP or a pressurized MAF, which is it? Will those filters flow enough? They look to be getting nice cool air that's for sure!
tim
Great. Hopefully you'll finally get the 60-130 time you deserve. 5.XX?Originally Posted by colorinc
The pics are deceiving, those are pretty good sized air filters especially when you consider it's using a pair of them! How's the weight compared to stock? Intercoolers seem to function half as heatsinks and half as radiators so a little mass seems to go a long way. Look like VERY nice pieces, I look forward to any test data you can provide - thank you!
Those things are massive
TIM!!!!! that was my next move! your one step ahead of me LOL
Yea Todd sent me pic's a month ago of those nasty suckers and then he teases me with some other INSANE looking 6" cores!! took mine out today cause Todd redid the program for me, HOLY CRA_!!! she HONKS!!!! Get those number up asap i would love to hear what you say. What fuel do you have in it?
I was thinking of getting a drum of C16 or MS109 Got to call Todd on that one.
oo man i have been saving up.. was going to go with the bell ic's but.. you know how it goes you might as well go all inOriginally Posted by PALETTE
TIM!!!!! that was my next move! your one step ahead of me LOLYea Todd sent me pic's a month ago of those nasty suckers and then he teases me with some other INSANE looking 6" cores!! took mine out today cause Todd redid the program for me, HOLY CRA_!!! she HONKS!!!! Get those number up asap i would love to hear what you say. What fuel do you have in it?
the 6 inch cores must be retarded looking lol email me the pics... what did todd do to your program?? what plugs r u running? i email todd yesterday im going to schedule some dyno time with him in the next couple of weeks to get her tweeked in
ill post the 60-130 after that and some dyno pulls the ride down should be fun but the ride back will be better
... im running sunoco supreme 114 oct tim
